Death Wobble after Mopar LCA install
coukos34
Boston
2014 Mini Cooper, 2016 Corvette Z51
I stumbled upon this video and I have to say it was a huge help:
Some simple quick tests and I was able to identify that I had the same loose connection as in the video, with the steering connection. Too late right now to investigate further, but I think this is a great way to easily identify what might be going on from a steering componentry perspective.
sweet88gt
FL
20 JLUR 24 VW Tiguan Rline 20+21 Tacoma TRD
What did you find that was loose ?
coukos34
Boston
The connection at the pitman arm to the steering. Not sure if that can directly contribute to DW, but it’s certainly loose.
sweet88gt
FL
I might have missed it but how many miles do you have on the Jeep ?
sweet88gt
FL
Once you get it back from the dealer I would be interested on the results.
DizzyIzzy
Izzy
NYC
2020 AEV JL370 - Hellayella JLUR
Have you looked at an out of balance tire to be the issue? Were the tires switched between the wheels during the LCA install?
coukos34
Boston
I haven’t but a good point. They did rotate the tires as well. I’ll have them check the balance.
DizzyIzzy
Izzy
NYC
Yup. As you mentioned in your initial post, not many variables were changed. So, it looks like it's either the LCA and/or tire rotation that resulted in this change. So, start small, check your tire balance first and then go from there. Otherwise, you can easily rabbit hole into this (tie rod, track bar, steering stabilizer, UCA, blah blah blah).
Let us know once you come back from the dealer, if you've managed to fix the issue.
coukos34
Boston
One other thought. When I flipped the steering stabilizer to the correct orientation, I initially loosened up the track bar bolt instead. I torqued it back down, but after taking for a test drive my steering wheel was off. I had to adjust it to get it back to center. Seems odd to need to do that given what I touched.
quietpeen
Chambersburg, PA
2019 JLUR
track bar has noting to do with your steering wheel, do you mean you loosened the drag link?
