Mounting ARB Air Compressor
CptFloridaMan
Gabriel
Orlando
2018 JLU Sport 2.0
Kinda bounced through the 50 pages as i’m planning to get either a twin or a single.
Would like to mount under either seat if possible, but is the wire harness that comes with it long enough to be ran to an aux switch under the hood like voswitch? Or would I need to extend some wires?
Or is it better to run it under the hood somewhere for plumbing and wiring?
And assuming i’d like to add lockers later, what is everyone doing for plumbing while it’s under the seat for lockers?
Tech Tim
Summit Sponsor (Level 3)
Tim
Poulsbo, WA
4x4 of all kinds
If you want an under-the-seat mount and planning on adding Air Lockers, then the genuine ARB UTS compressor mount is probably your best bet: https://www.northridge4x4.com/part/...0220-arb-twin-air-compressor-mounting-bracket
It mounts under the driver or passenger seat and is designed to work with the ARB manifold, locker actuator solenoids, Lynx system etc.
Jeep Wrangler JL Mounting ARB Air Compressor JL_Compressor_bracket-300x278
1996cc
Oregon
22 JLUR 392
If under seat, you could still mount the little reservoir and solenoids under the hood. Just need a longer hose between.
CptFloridaMan
Gabriel
Orlando
2018 JLU Sport 2.0
Out of curiosity, how would plumbing look for lockers if it’s under the seat? As in to mount the manifold under the hood, what’s a good option to plumb a line from the compressor? Does it fit in the grommet in the firewall Im assuming?
X-Treme
New Mexico
2022 Rubicon 392
Happily Retired
Grimm off-road mount.
That’s exactly where i put mine
It’s a great setup. The one I have. I added a dust cover for the air fitting.
yep, thats where i put mine. My air fitting is in front next to my winch. I added a Sherman dust cover cap to mine as i live in the dusty NM desert.
Jeep Wrangler JL Mounting ARB Air Compressor 263C56B8-8DAE-4DD9-A27F-747FA4B12ED2
Tech Tim
Tim
Poulsbo, WA
4x4 of all kinds
The ARB manifold mounts right to the bracket, you can see it in the pic.
The actuating solenoids mount to the manifold and then the air lines run out from there.
If you wanted to mount the manifold under the hood, you'd need a long enough SS air line to go from the compressor to the manifold.
Grimm Offroad offers a bunch of different length SS air hoses, here is an 80"er: https://www.northridge4x4.com/part/...ies/10058-grimm-offroad-braided-air-hose-80in
smokeythecat
2021 Willys Sport 2-door, 2019 Mini Cooper S
No room under the JL seat.
Is that because you already have something mounted there? I installed the InnovativeAT 4-tire system under the passenger seat and I love it. It is so easy to air down and up, and when something is easy to do you tend to do it.
CptFloridaMan
Gabriel
Orlando
2018 JLU Sport 2.0
Thanks for the link, I think i’m leaning towards the grimm fender bracket due to it having the heat shield. Small question, does it have any issues with fender liner clearance? Running paramount fender flares which look to be just like OEM.
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
Your safe with factory liners, or any others that aren't of a high tuck design.
JLAFAKASI
Lito
Richmond, VA
JlU Sport S 2019
you got pics of dif angles of those fender flares from paramount?
sardogtella
Burlingame ca
2012 JKUR. 2021 JLURXR
I second the Grimm Offroad mount. It was easy to install and the filters are up out of the dirt in the engine bay. Grimm customer service was great. I originally purchased the wrong model bracket and they sent me the proper bracket free of charge.
CptFloridaMan
Gabriel
Orlando
2018 JLU Sport 2.0
Let me get off work I’ll snag a few photos for you, for the price they’re decent. I wanna replace them with paramount again later because of some small fitmejt issues eventually.
Membrain
Dirk
DFW TX
'21 XR392 / '24 XR392
Engineer
lol - keeping this thread going... I have a 392 and am not seeing any room under the hood, so either under the seat or under the cargo compartment floor... for those who were asking about in the cargo area but behind the rear passenger side seats might want to look and some of the JK MOLLE panels that mount back there.
OnlyOne
Northwestern New Mexico
2021 Sport S Diesel on 37s
At the time that mount didn’t exist. I don’t run a ARB anymore. I have a powertank.
