Mopar Tailgate Integrated Air compressor
Beowulf
Jeep Wrangler Rubicon Unlimited
I hope they add it to the gladiator to compete with the Tacoma trail hunter
Javwohl
Denver
17 vw gti, 2001 dodge ram, 202 jlurd white, 2005 mazdaspeed Miata lava orange
engineer
Also be interested in the full specs of this, and see a comparison between it and the arb.
I like how this is set up and you can do 4 tires at once is also nice but how long it take to air up? And how long it will run?
jromanmd
Jon
Annapolis
2023 Jeep Wrangler Rubicon
As an alternative, consdier the dual ARB install kit from American Adventure Labs in Utah. I just ordered this. Compressor fits in the little plastic housing in the back. They also have an optional mount that goes just behind the driver C pillar. Pretty slick looking and ARB reliability. Loving AAL's stuff. Aluminum, lightweight, nice. And, their prices are on this planet unlike the stuff that's getting shilled on youtube all the time (you know the brands). https://americanadventurelab.com/product/jeep-jl-dual-arb-compressor-mount/
Stupid Question (I Know) but why would you need a separate battery if you want to inflate with Engine Running. Similar to a Winch?
Sand Flea
Lewes DE
2025 JL Wrangler Unlimited, Sahara
Federal Firefighter, Retired
And how hot does it get in that space.
OminousSkitter
The Ether
Trek Bicycle
You know that indention where you can put your can/cup right above it? That becomes your overlanding stove.
(I have no actual experience with it and am only kidding, but airflow seems low and I would imagine it gets pretty warm)
Javwohl
Denver
engineer
Yep this what I was thinking too, I was originally going to get some panel to mount to the tailgate then mount an arb dual pump then get a 4 tire inflator kit to air up all the tires.
But this is a little cheaper and more integrated taking up less space.
Javwohl
Denver
engineer
So what your saying is if you do a lot of snow wheeling this be great so you can air up your tires and heat you hot cocoa all at once.?
(J/k of course)
AnnDee4444
'18 JLR 2.0
Maverick909
I.E.
OminousSkitter
The Ether
Trek Bicycle
ok ok. this might be the best spot yet for the compressor.
Ish? It means you can never go to an aftermarket tire carrier. I also wonder about the higher current lines running next to the camera, but it's not likely you're using the compressor while backing up.
yokramer
Snark Incarnate
Anyone ever figure out what compressor they are using in there?
