Need a new air pump/air compressor they keep breaking
Maverick909
I.E.
www.instagram.com
your best option is the viair. ran mine with 35's four almost four years without issue. gave it my brother when i went to 37" tires now i have a 100% duty cycme dual compressor. gets the 37's filled up in about 10 mins or less get the RV version its a 100% duty cycle. its a little slow to pump up but that is the trade off for the better duty cycle. 35's are easy to fill. Also spend once cry once. currently your two compressors in with catastrophic failures. Spend the 150-250 bucks to get a nice viair setup that just clips to the battery and comes with a storage bag. you wont be disappointed
ParadigmDawg
Greg
Fort Worth TX
Amazing that I got to Page 3 before someone mentioned the chalk test. @Tyler88 watch a couple of YouTube videos on it, super easy to do to identify the proper PSI for your rig/tires.
As for compressor, highly recommend the VIAIR as well ( Amazon.com: VIAIR 400P/40043 Portable Compressor, Tire Inflator Kit, Offroad Air Compressor For Truck, Jeep, SUV, And Car Tires, Portable Air Pump Kit, Car Accessories, For Up to 35" Tires, 150 PSI/2.30 CFM : Viair: Tools & Home Improvement )
Slightly over your $200 budget but well worth it. I also prefer portable as I can toss it in my wife's car if needed (or any other vehicle). You definitely want one that clips directly to the battery as opposed to using a 12v (cigarette lighter) plug.
If you're going to be airing up/down a lot, I'd also highly, highly recommend budgeting/saving up for a Speedflate system. I got one recently and it's just so nice to air up/down vs going tire by tire.
I play like I love my Morrflate 4 hose system around my wife but in reality, I save about 1 minute compared to her airing up 1 at a time by the time I get everything out, fill up and put everything away. It looks like I am fighting an octopus at times. :) I do like not having to bend over though.
BigGame
J
Annapolis, MD
2019 Jeep Wrangler Rubicon Unlimited
There is no one answer for a given time. It all depends on how much weight you have on them. And, of course, what you're doing.
There really is one answer for the placarded tire pressure. That’s different than adjusting from the placarded posted tire pressure based on conditions and perhaps load (although a jeep does not have much of a load range). For his Jeep, with those tires the conversion from posted placard pressures (inside the door jam) is 35 psi. 50 psi would not be the correct answer for any situation with that vehicle.
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
My Jeep's about a thousand pounds over what a standard placarded tire pressure would indicate. Are you thinking that that's irrelevant?
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
Well...
Jeep Wrangler JL Need a new air pump/air compressor they keep breaking 1705442219248
Note, the stock loading is like 40% over the GAWR for the Jeep, so there's some room to play with comfort/wear.
stellarpod
Stephen
OKC, OK - USA
2019 4-door Wrangler Rubicon Unlimited
I bought this Milwaukee M18 Model 2848-20 inflator/compressor recently but have not had a chance to test it on the trail yet. Nonetheless, it has worked extremely well around the garage.
Milwaukee M18 Inflator Model 2848-20
It tops off tires quickly, has the ability to preset wanted pressure, thus allowing you to set it running and go about other chores. And it uses ubiquitous M18 batteries. A High Output XC6.0 battery seems to last a good long while. Carry an extra battery or two and I'd suspect you'd be well covered.
Do not confuse this for Milwaukee's previous lackluster Model 2750-20 battery powered inflator, as it is far inferior to the one I linked above.
I'll provide an update once I get a chance to put it through its paces.
wreck99
Matthew
SC
2024 JLU Rubicon, 2019 RAM 1500 Bighorn
YES!! “Thors Lightning“. We have used ours many times even in 16 degree weax. They are veteran owned and stand by their gear.
I just saw a video of this in action. Pretty impressive.
DaltonGang
Doesn't Play Well With Others
