Longer LCAs worth it?
JJ_WA
JJ
Puget Sound, WA state
2002 Dakota, 2017 Cherokee, 2023 Willys XR
Retired US Army, Higher Education
When I ordered my Willys XR in December '22, I read a lot about getting the longer LCAs and the improved handling of the Jeep, so ordered a pair. After nearly 5,000 miles I haven't felt a compelling need to put them on. The Jeep's been handling fine at both low and high speeds, and the very minimal off-roading we did at Yellowstone. Even She who must be obeyed likes the handling when she drives it.
For those who have made the switch, have you felt it to be worthwhile? They've been sitting in my garage, gathering dust.
DewHawk
Rob
Aurora, CO
'19 Stinger GT2, '04 M3
USAF F-16 Crew Chief
My last 4xe Rubicon I installed the mopar lift LCA’s as a test to see if I’d notice a difference. Mind you I threw on AEV’s spacer lift and 37’s too. I didn’t notice a difference positive or negative but on stock height and tires I can imagine the highway stability being marginally improved. It definitely can’t hurt to try them. ?ā€ā™‚
JJ_WA
JJ_WA
JJ
Thanks, @DewHawk. My XR has the factory (slight) lift and 35's. I might do the swap in the Spring.
The Fixer
North Jersey
2018 Mojito! JLS, 2018 Firecracker JLUSS
Teacher
Here's my experiences with the Mopar longer LCAs. My son and I installed 4-door Rubi takeoff springs (60/61 and 90/91) and shocks on my 2-door JL along with 33's. I drove it for a couple years that way, then added the Mopar LCAs last summer. They helped reduce the amount of steering input and twitchiness out of the frontend at highway speeds, but I think that's probably more related to the short wheelbase.
I only say that because my son's JLUR has the same springs and it doesn't feel twitchy at highway speeds. And my wife's JLU now has Rubi takeoff springs as well (59/60 and 90/91) and it drives the same as it did before.
I know the extra caster won't hurt it, but is it really necessary? Seems like it might make more of a noticeable difference with a lifted 2-door.
At Risk Ute
Christian
ā€˜23 392 XR
Retired Navy
I noticed a positive difference on my two XRs. More planted in turns and bumps like expansion joints. Surprisingly easy install.
Would love to know how much Jeep saved not putting them on at the factory.
At Risk Ute
Christian
ā€˜23 392 XR
Retired Navy
Perfect description! Less twitchy with the longer ones.
Roky
Roky
If it ain’t broke don’t fix it…… but as good as it feels now, it will still improve with the lcas….
The Fixer
North Jersey
Teacher
Good point, the XR does have even taller springs than a Rubi so the caster has to be pretty low from the factory. If an XR is almost as tall as a Mopar-lifted JLU they should put those LCA's in from the factory.
jmr
Wentzville, MO
'24 JL Rubicon Unlimited, '25 JT Mojave
I put them on my '22 Willy 2 door and they did help the wandering at highway speeds. I've ordered the Mopar LCA for my '24 JLUR even though it drives better than the 2dr Willy did.
hoag4147
Colleyville, TX
2022 JLUR XR
JJ- just wait and put adjustable LCAs on when you go higher for the 37s you will be putting on soon ?
Jeep Wrangler JL Longer LCAs worth it? IMG_0373
JJ_WA
JJ_WA
JJ
With my accountant (She who must be obeyed) keeping a close eye on expenditures for the Willys, I'll have to run the 35s down to the nubs before I can talk about upgrading the tires. That, and she is somewhat vertically challenged, so although she's limber and lithe, it's a bit of a climb into the Jeep~
Fast-n-Furious
PA
2022 392 XR
My XR drove very good before the Mopar LCAs swap, both local and highway speed. I was just looking for small projects. Honestly it feels a bit better, I still have a slight pull doesn’t bother me. Tracks a bit better. To me it’s not too obvious or that much of a difference. No regrets anyway. You can tell the caster angle difference. If you don’t consider additional lift, the factory LCAs are fine as long as it tracks well to your liking. If you will go taller, adjustable LCAs may be the way to go.
Jeep Wrangler JL Longer LCAs worth it? IMG_4528
Jeep Wrangler JL Longer LCAs worth it? IMG_4687
Jeep Wrangler JL Longer LCAs worth it? IMG_4824
TheBirdie72
Rhode Island
2021 Jeep Wrangler Freedom Edition 2 Door
Rubi suspension on two door sport with 33’s here. I sprung for the adjustable LCA’s and had them dial castor in at 6.5. It was a noticeable improvement in handling. Much less highway wandering & steering correction. And good to go if I go higher/bigger down the road.
Jeep Wick
Wick
America
2022 High Tide XR
Mechanic
The LCA were a significant improvement on my 2 door, much less wandering and easier to drive. It makes sense that your longer wheelbase is more stable, but you won't regret doing them.
