Is Tailgate Reinforcement Needed?
Spank
What fine tuning are you referring to? My EVO carrier lined up perfectly. I used one shim for my 35" tire per their recommendation.
I think you're in the minority then. I had no problems getting mine lined up AFTER adding some additional washers between the carrier and the spacer plates because the gate was actually warped outward. I think the holes on the mounting brackets that connect to the tub, at least on mine, weren't drilled in the proper position.
I'm not shitting on the product. It's fantastic. But if you look at various photos of this product installed, even from the manufacturer themselves, most people don't seem to get the gate lined up properly.
https://www.jlwranglerforums.com/fo...ody-mounted-tire-carriers-available-now.16641
https://www.offroadevolution.com/product/evo-mfg-jl-hd-hinged-tire-carrier-black/
Even on their own product photo, you can see the gate still needs some tweaking, even if it opens and closes just fine.
Here's mine, which is aligned beautifully, but required additional hardware to make it so. That shouldn't have to be the case.
SecondTJ
Il
Jeep
Is it possible that what the owner manual means by 85 pounds is additional?
As in whatever you add has to fit in 85 pounds and that includes the spare's additional weight if you go bigger?
As some have mentionned the regular Rubicon tires and already rather heavy.
Maybe we should get Jeep Cares involved to get an official answer?
It is not 85 additional pounds.
Wrangler’s tail gate weight limit has been listed at 85 lbs since 2014. That includes the spare tire weight, factory or oversized. This isn’t some new mystery.
gpurp
North Texas
19' JL Sport 2dr
I put the Evo carrier on straight away before getting larger tires. Maybe it lined up right because the tailgate never had a heavy tire mounted on it.
Fast forward to after the carrier and 35's were mounted. I noticed the tailgate dropping maybe 1/4" when I open it. Called Evo and they said this is due to the tub flexing under the weight. The latch is what keeps the tailgate level.
At least I know the carrier isn't going to sag, warp, or get torqued. It's heavy steel.
gpurp
North Texas
19' JL Sport 2dr
pablo_max3045
Germany (ex-pat)
2019 Rubicon
Engineering project manager
If you do a lot of washboard / corrugated roads then you are better off to get one installed. Better yet, relocate to a swing out carrier tied to the bumper / frame
That type of continuous driving is what causes metal fatigue. Especially when there is 60kg hanging off the back.
Rustydog
Palm Desert & Big Bear Lake, Ca
2019 JLU
They way I have read it multiple places even on this forum is that the 85 lbs rating is in addition to the spare.
Adamoni
2020 Rubicon Recon (2.0T w/ eTorque)
The wording in the owners manual is pretty clear, it literally says “including the weight of the spare tire”
Logically and grammatically I think this is not clear, or perhaps, cear as mud. The last part is what throws me. It’s like saying “if you put a roof rack on your car it cannot exceed gross weight of 1000 pounds, including your car”.
On second thought, it’s the first part that throws me. It’s debatable what the word “it” is referring to. Is the word “it” referring to the accessories or is it referring to the spare tire mounted carrier?
UKCATS
DFW
2024 392 Rubicon(sold)/2025 Lexus ES 350/2025 BMW X5
I play piano in a whorehouse
Guys, this is the answer. Not sure why the confusion. The max on the stock rear hinges and carrier is 85lbs. Period.
Hayseed_JLUR
Midwest
2019 JLUR, 2015 JKU
According to this statement, the tailgate is not limited to 85lbs but the tire carrier itself - not the hinges or tailgate. This also includes the weight of the carrier itself (stating "gross" weight). If this is correct then the hinges are not the weak point but the tailgate sheet itself. This would explain why Jeep/Mopar feels their reinforcement is sufficient.
Hayseed_JLUR
Midwest
2019 JLUR, 2015 JKU
I question whether they were using the correct tire bumpstops on the carrier after going to that set-up prior to installing the ExpeOne.
pablo_max3045
Germany (ex-pat)
2019 Rubicon
My point exactly. If Mopar makes a tailgate reinforcement bracket, which, obviously is to accomodate a bigger spare, and this bracket is also, obviously added weight, then all this is pointless if the original spare tire is riiiiiight on the limit to begin with...
At the end of the day, it is still attached to aluminum body panel though, isn't it? Which, while lighter and rust resistant is far more given to metal fatigue.
guarnibl
Scottsdale / Sarasota
'09 JK, '26 Willys
We put on a Motobilt carrier...it's very similar to the EVO. Fits really well. Wasn't really fond of their brake light/license plate solution, so didn't implement it. Will probably remake the bracket to some other config. For now, the brake light's just zip tied in there.
I went with it over a bumper mount b/c I want to make the rear bumper pretty minimalistic and that negated making something large enough to mount a larger bearing pivot, so it had to go on the body.
That said, coming off a steep ledge or going up a big waterfall will require either tire removal, or being extremely careful with line selection with a body mounted spare. You catch the bottom of that tire and lever it against the body and you're going to wish you'd gone bumper mount.
Good point that I never thought about. I'll have to consider that for Moab this year.
Spank
Watch this at around the 1min mark. It might help you decide. Then watch later with reinforcement.
While they're not wrong that the stock gate and tire carrier aren't really designed to confidently carry more weight, this video is somewhat disingenuous. The bumpstops don't reach the tire, which will naturally cause vibration. Whether you buy aftermarket bumpstops or use something as simple as rubber hosing, you always want to make sure the tire is flush against the bumpstops to avoid exactly what is going on here. This is what wears out the gate more than simply adding weight.
You'll notice in the parked shots how they totally avoid showing the bumpstops, especially when they're panning down from the side.
