- Banned
- #16
I mean, sure, if your rig is all over the road like a drunken sailor then yeah adjust away cant hurt can only help. But should be needed unless there is another underlying issue..that's allThat's what I would of thought too, but here is an example of adjusting caster fixing the steering problems on a lifted JL. He actually went from giving up and trading it in, but fixed it via caster adjustment.
Thread: https://www.jlwranglerforums.com/fo...use-of-the-crap-steering-good-bye-jeep.14924/
Conclusion post confirming the fix: https://www.jlwranglerforums.com/fo...eering-good-bye-jeep.14924/page-7#post-401807
I called Teraflex about their JL drop bracket kit to ask a question to help out another JL owner and Teraflex told me they are getting many validations on this kit fixing the problem on Mopar Lift Kit steering issues. I asked them why some JLs don't need this and some do, they said because the alignment component geometry is inconsistent thus some JLs need it and some don't. This aligns perfectly with why some stock, non-lifted JLs don't have the steering issue and some do. You can have 4.5 caster on 2 different non-lifted JLs and one wanders / drifts all over the place and the other one doesn't, then adding the longer lower controller arms on the one that wanders/drifts getting it to 5.5 caster then stops drifting. Again, all due to different geometry in the front end, like the welding locations between critical parts are off on some and some are exactly where they should be.
There are at least 2 or 3 examples of lifted JLs being fixed with adjusting caster in the steering thread at https://www.jlwranglerforums.com/fo...ering-feels-like-it-has-play-and-drifts.3691/. Way too many posts to re-read to find them.
After verifying tire pressure, other alignment variables, checking springs, verify correct torque on ball joint nuts, etc., then caster would be the next step.
