2 inch mopar lift installed
hoag4147
Rick
Colleyville, TX
2022 JLUR XR
I do have the rk correction perches,are you suggesting I switch the front springs
What color is part number tag on each side?
Roky
Roky
No,I my need an alignment,if I’m correct,the caster would be the angle of the pinion if so the the mopar lower control arms should correct that
You probably need more caster, from the looks of your pic, you got more than 2” of lift, and that’s all those control arms are good for. So your slight pull may actually be wandering from low caster.
4xFUN
Scottsdale AZ
2024 2-door Ruby-X, 2020 2-door Ruby, 2023 RAM TRX
No, I think if the springs were reversed and with RK perches, I think you would be much greater than 1/4". On mine, removing the RK spring perches and replacing with the Mopar that came in the kit did reduce the lean by just over an 1/8". If you still have the Mopar spring perches, look at them side by side and you will see the passenger side sits taller than the driver side while the RK perches are the same height...
Cmt
Carl thomas
Toledo ohio
2019 Moab 2017 challenge Scat pack 2010 zx 1400
Chrysler transport(switcher)
The mopar lift is known to be more like 3-3 1/2,i wouldn’t think the castor would cause it to drift,I will attempt a wheel alignment and get back out here and let you all know the results
Cmt
Carl thomas
Toledo ohio
I will dig them out and check,thanks
