Mopar 2” Lift Installed
WranglerAz
Arizona
2018 JLUR, 2019 JLR, 2000 TJ
My lift is being installed today, as are new wheels and tires, I am having an alignment done, it makes sense to me since the geometry has changed with the parts.
JK47
Surf City USA
JLU
The only thing they can adjust is toe and straightening your steering wheel. The lift doesn’t affect toe, and it’s easy to straighten the steering wheel.
If you had adjustable track bars and control arms it would be a different story.
WranglerAz
Arizona
True, but it also gives me a base line, and builds a rapport with the small shop I am using, so it was worth it to me. I think it looks good too.
JK47
Surf City USA
JLU
A baseline for what? The factory specs are included with the Mopar kit.
WranglerAz
Arizona
Numbers are important, but they are not everything, I was building trust with this small shop, and confidence that my JLUR has no known issues, each of those together are the baseline, works for me. Where is Surf City?
JK47
Surf City USA
JLU
Google is your friend.
Without adjustable track bars I can tell you from here that your alignment is off.
WIJLU
Eric
Wisconsin
2023 392 XR
Your front axle is shifted to the driver's side and your rear axle is shifted to the passenger side. You kind of have to look close, but will be off about an inch or so.
FrankieFJL
Frank
Massachusetts
2018 JL Rubicon
IT Professional
So are the axles off center because the stock track bars are too short post lift and are under stress? If so, do the aftermarket (longer) track bars relieve the pressure and allow the axle to return to it's normal position without the stress? Is that how they work?
JK47
Surf City USA
JLU
Basically yes
Jeep Generation
Kevin
San Dimas CA
www.youtube.com
2018 JLU Rubicon, 2014 JK Willys, 1999 TJ Sport, 1966 CJ5-A
Here is my 37 KO2s hitting John Bull. The Mopar lift is great. I am going to post a install video of the lift hopefully by this weekend.
Jeep Generation
Kevin
San Dimas CA
www.youtube.com
I finally got the time to finish editing this. Here is the install video I promised. If you have the instructions, you can follow along step by step, I have step number posted in the top left corner of the screen. Per the instructions. You can download the instructions from Quadratec.
Jeep Generation
Kevin
San Dimas CA
www.youtube.com
If you guys lifted your jeeps with the Mopar Lift. Check this out. You'll need need track bars. My axles were off by 3/4". This fixed it. Made the ride smoother on freeway, hitting speed bumps was smoother and helped MPG.
