Mopar 2” Lift Installed
RedJlu
Elvis
Queens, New York
2018 firecracker red Sahara (sold); 2021 Sting Gray Rubicon (ordered)
If you guys lifted your jeeps with the Mopar Lift. Check this out. You'll need need track bars. My axles were off by 3/4". This fixed it. Made the ride smoother on freeway, hitting speed bumps was smoother and helped MPG.
Is the same trackbar that comes in the adventure 1 series?
Jeep Generation
Kevin
San Dimas CA
www.youtube.com
2018 JLU Rubicon, 2014 JK Willys, 1999 TJ Sport, 1966 CJ5-A
Probably. I looked at their website. I didn't see the part numbers with the parts in that lift. Here are the parts numbers I used...
RK06187 Front Track Bar
RK06692 Rear Track Bar
RK05495 000 Grade Grease - 3oz tube
Bearman95
Chuck
Ft. Worth
2018 JL Rubicon
It’s kind of weird how the Mopar 2 inch lift works great for some people without adding other components and for some the experience was not very good!
GRAK
Out West
JL Rubi, Corvette
Ok.... So, on road....MUCH better than my spacer kit. I should also note that I’m running at 30 PSI.
Went off road today-Absolutely flawless. Ran the same trail that I did in Big Bear a while back, which was with a JK 3.5” lift on 35’s.
Today was the 2” lift with 37’s, and I felt more stable than ever. Had it tilted at 23 degrees to the passenger side, and couldn’t have been happier.
The RK spring pads worked perfect btw...
37’s and no rub at full stuff, that’s great info :sun:
