Injen High Tuck Muffler
XX4XEXX
JD
Ca
2021 Rubicon
Mechanical Engineer
Anyone install Injens High Tuck muffler on a 2.0 yet? Sound clip would be great...
AFD
Northeastern US
2023 JL Rubicon (2DR/V6)
Not sure what happened, but they used to have 3.6L and 2.0T factory-made video clips on their site for that exhaust. Now there's only the 3rd-party review.
While likely not identical in sound, @ExpeditionBuilds installed the AFE Mach Force-XP high-tuck muffler on his 2.0T, which is very similar in size and design (see vid below). A Savvy high-tuck should also sound similar, but there's even fewer clips of that one.
It's amazing that so many exhaust companies somehow think it's a-okay to sell an expensive product without bothering to make a few decent sound clips. Anyway, let me know if you find that Injen for a decent price!
Decreasing Dave
Temecula, CA
2023 JLURubicon XR
Retired Federal LEO
I had the Injen on order and the supplier took 2 months and still couldn't get it for me.. I cancelled it and went with the AFE, the same as above. It was cheaper and it sounds EXACTLY like it does in the posted video. I also agree with his assessment of the throttle and power. I couldn't be happier. Nice throaty sound versus sounding like a Ford Pinto.
AFD
Northeastern US
I really wouldn't mind buying the AFE version instead, especially since it's nearly half the price, but was mostly interested in getting my exhaust components in the higher quality T304 stainless steel since our roads are salted like crazy up here. Also kinda prefer the straight-through design versus AFE's offset inlet/outlet. As far as sound, think the AFE actually sounds a bit better and just slightly more aggressive and burbly than the Injen, probably due to the offset.
And I drove a Pinto for several years and honestly can't remember how it sounded at all ?
JP29
Zach
Olathe
2020 JL Sport
I have the Injen along with the CAI and some other mods, I'll see if I can get you a vid with some sound later today.
XX4XEXX
XX4XEXX
JD
Ca
2021 Rubicon
Mechanical Engineer
XX4XEXX
XX4XEXX
JD
Ca
2021 Rubicon
Mechanical Engineer
Appreciate you guys thanks. The reason I was leaning towards Injen was for no sound or minimal. I actually like the fact of a quiet rig in my old age. The days of loud exhausts are being me now ?. The AFE is a superior product and build quality and might be a choice.
kah.mun.rah
Merenkahre Jr.
Duat
2.0? And sound clips?
I have the 3.6L. In the video in the link below you can hear the sound of it at full throttle.
Most of the noise is from the CAI so if you are looking for a quiet ride, as you probably know, don't get the CAI. I am not sure if the muffler is louder or quieter than stock but does have a more deep tone.
https://www.jlwranglerforums.com/forum/threads/0-60-collection.101865/post-2111384
Videos at this link also have some of my muffler noise examples:
https://www.jlwranglerforums.com/fo...ou-do-to-your-jeep-jl-today.3033/post-1958404
  • Like
Reactions: AFD
XX4XEXX
XX4XEXX
JD
Ca
2021 Rubicon
Mechanical Engineer
Appreciate the links! Was looking for the 2.0 but I'm thinking Injen or AFE might do the trick. On the AFE I might leave out deleting the resonator and just connect after it to keep it quiet.
AFD
Northeastern US
Think you can buy the AFE as just an axle-back muffler without changing the midpipe/resonator.
Edit; you can. 49-48080 is the axle-back only (and 49-48079 is the full system with midpipe)..
https://afepower.com/afe-power-49-4...-409-stainless-steel-axle-back-exhaust-system
JP29
Zach
Olathe
2020 JL Sport
I meant to reply to this sooner, but I spiraled down the rabbit hole on my exhaust. I initially installed mine without removing the indexing rivet on the midpipe - which led to the axle back eventually becoming loose. I did recently remove that rivet, but have now come across the exhaust kicking out a kind of odd (worrying, frankly, but I'm probably just being neurotic) burbling on startup and when decelerating and letting off the gas. I'll get a recording a little later - for real this time - but I'm not sure if it's to be expected or a result of a bad baffle internally or what.
AFD
Northeastern US
On the Injen muffler? I thought that one already had the notch cut out for the OEM indexing rivet?
JP29
Zach
Olathe
2020 JL Sport
Not that I saw, I actually spread the pipe to fit it over the rivet first, but it eventually slipped back off of it.
  • Like
Reactions: AFD
