I have to ask. Are you sure that squeak is coming from Sky Top? I have a Sky One Top since May and it doesn't make a sound.
It is coming from the side panel and latch to hold the panel in. The side panels rattle like a styrofoam lid cooler and the squeak is from the latch system. There are a few threads on this: https://www.jlwranglerforums.com/fo...movable-windows-squeaking-noises.25487/page-6I have to ask. Are you sure that squeak is coming from Sky Top? I have a Sky One Top since May and it doesn't make a sound.
Sure you know you can control how far you open Top. Have you opened a couple of inches to see if you hear that still? Just asking.
I just read the thread you sent. I just went and looked at mine and they are very tight that they cannot move. Think my rubber seals are thicker and hold tighter when latched.It is coming from the side panel and latch to hold the panel in. The side panels rattle like a styrofoam lid cooler and the squeak is from the latch system. There are a few threads on this: https://www.jlwranglerforums.com/fo...movable-windows-squeaking-noises.25487/page-6
I have been to the dealer ~8 times for this and they have tried multiple things to fix: adding additional weather stripping, adjusting the latches, etc. I have tried the straw trick over the metal pin, anti-friction tape on the metal plate of the latch, etc. If you push out on the panel the sound will go away or if the panel is removed it is fine.
Oh my god, that's terrible!
I have a 2019 Sahara one touch.... having issues with it leaking in the back. been to the dealer three times. They say them leaking is just un heard of... I just got lucky, I noticed water running down back window on the inside !! getting a new seal for the third time. hope this fixes the issue. I have not heard of one other person having a leak. I as well was told don't go thru automatic high pressure car washes with dryer
No offense I hope it stays that way. I hope yours is fixed. Good luck. I went from a Honda to the Jeep and the Honda had no issues up to 130k miles. I have no doubt the Jeep won't even come close to that. LolLOL, I said the same thing at 5500 miles. I was hoping someone would steal it at the garage this last time
My cold record is 21 degrees Topless. Will I open Jeep in the rain no. Leather and rain don't like it. lol, I get more stares from Non- Jeepers when its 30 degrees and I stop at light windows down and Top open.It’s highly unusual that I don’t open my roof daily. Light rain on the interstate - yep. 37 degrees yep (seat heaters and steering wheel heater turned on). Absolutely love it!
What happened to the top that was removed ? Sent back to factory, or Dumpstered ?Got my Jeep back today. 4th time in the garage and about 50+ days in the garage. Replaced the top last time. This time replaced the bar across the top, the latches, and the weatherstrip. It sounds a lot better and seems OK. But I've only drove it 10 miles. I guess I'll now soon enough if it's finally fixed
