Ideal offset/backspacing JL
MSchir1
Cherry Hill, NJ
Wrangler JL Sport
Here's 8.5+10 on 295/70/17s, not much outside the fender and no rubbing issues on stock suspension
Any chance you can snap a picture of the insides at full lock? i just got the same tires and am about to pull the trigger on 8.5+18 but am still hesitant. Thanks.
blnewt
New Mexico
Just ask @cosine he knows!
Here you go, first shot is down the backside of drivers side full lock, nothing close.
2nd shot inside of passenger side on the front, again, no problems
3rd shot real close at the lower edge of plastic bumper trim, about 1/4" or less, but no problems at that tire diameter, any taller and trimming would be needed at stock height. Your +18 will be fine in that regard, much more than 8mm clearance lock to lock.
Jeep Wrangler JL Ideal offset/backspacing JL 100_4081
Jeep Wrangler JL Ideal offset/backspacing JL 100_4082
Jeep Wrangler JL Ideal offset/backspacing JL 100_4083
MSchir1
Cherry Hill, NJ
Wrangler JL Sport
Thank you!!
Chadfromtoronto
jaidyn
toronto
2018 JL manual sports s 2-door
Hi, I got my first Jeep , JL 2 door sports S, about a year ago and looking to change my wheels and having trouble finding all the info about offset and backspacing. seems like JL has wider stand compared to JK and AEV is still working on the recommended offset/backspacing.
I have to be on the highway a lot so i was thinking of minimal tire size increase. so factory 245/75/17 tires to Falken Wildpeak AT3W 265/70/17 .
With that change i wasnt sure what the rim offset and backspacing I should be looking for.
Could someone please explain what offset and backspacing would work? and is there any stand difference for JLU and JL 2 doors? just wondering if any discussion i find about JLU is applicable to JL 2 doors.
Thank you
blnewt
New Mexico
Thank you
That's a pretty mild tire up-size so running a conservative (more positive) offset will be fine. If you plan to lift your Jeep down the road you would want a less positive offset to allow for suspension flex. No lift you could run a 17x8.5 +25 to keep tires close to the fender edge, if you plan to lift a +10 should be fine w/ those tires. If you plan to get larger & wider tires in the future then wheels at 0 or even a bit negative might be better.
As far as 2dr vs 4dr, the fit at the fender is the same, the Rubicon in 2 & 4dr have wider axles.
sarah.sosnicki
sarah
Tampa. FL
n/a
Planning on getting the 2 inch Mopar lift with 35x12.5R 17 or 18 nitto ridge grapplers. For wheels I am looking at the Fuel Anza or Fuel Krank but I am confused when it comes to backspacing/offset. Can anyone help me figure out what the best setup would be with this lift, tires, and wheels.
JEEPJL
South West Florida
2018 Jeep unlimted Sahara JL
Hi Sarah - Mine have a -12mm offset which makes my tires stick apx. 2"
I hope this helps
Jammer
Ft worth
Bright white JL Rubicon
do you have the Rubicon if so put 37s because it will lift it 3 inchs and with 35s it will have a big wheel gap if its a Rubicon
blnewt
New Mexico
AEV nailed it with their Pintle JL wheels IMO. I've ordered a Mopar lift, AEV wheels and 37" Patagonia's. I flat tow my JLR to trail head and wheel it like I stole it. DD concerns not considered.
Sounds like a great setup, even for DD'ing!
SleepEatJeepRepeat
Newport Beach, Ca
2021 JLUR, 2020 Audi Q7
Looking at Jeep stuff all day
I am looking st the fuel shok 17x10 wheels, with 315x70r17 Toyo mt wheels.. the back spacing is 4.75 and off set is -18.. having trouble finding photos of a similar set up.. can anyone share photos of a 4.75 bs with -18 offset l, running 45ish tires..
I have the teraflex st1 lift with fox shocks (just an fyi)
Fire Burns
Fire
CA
Zero (0) offset, 4.5 in backspace. Hostile Predators.
Some mild sticking out, about what I wanted, and compatible with most lifts
Jeep Wrangler JL Ideal offset/backspacing JL Side (2)
Jeep Wrangler JL Ideal offset/backspacing JL 3qtr
Foster_WV
Foster
WV
TJ & JLU
Can someone help me understand backspacing and offset?
Wheels I’m looking at are
17X9
5X127 5x5?
-12 offset
4.500 back spacing
71.5 Bore
27 lbs is that bad?
Tires will be 315/70R17 BFG KM2
Mopar 2” Lift
Thanks
Fire Burns
Fire
CA
ChattVol
Tennessee
JLU 4 door
