Gladiator Fox shocks on JLUR?
BIOSYN
Mojave Desert
2021 JLUR
And that where the Mojave 2.5 by-pass shocks come in to play :)
They are my first time with by-pass shocks. A true game changer.
I would be very curious to see how they would handle on a stock JLUR. I'm often tempted to give it a shot whenever I see Mojave takeoffs come up for sale.
Kevin Mojito
Washington
2019 JLUR Moijto 2005 TJ AEV Hemi
The Synergy Springs I have on now, are the closest to stock rates.
While I have not tried the Mojave on stock Rubicon springs, I would say they are very close to stock rubi reds. They will be a touch softer " road ride" , but will take the hit in the bypass zone without "bang or clank" of bottoming out.
Honestly, I would not spend the money on an up graded shock unless I went up to a bypass shock. The Mojave is a cheap way to get into the bypass shocks. I have run the Fox 2.0 Accutune LSC adjustable 2.0. Then other's on my TJ. The up graded aftermarket are good, but it's a real change to go bypass.
I have a set of the Fox 2.5 DSC I'm going to test soon. I'm too cheap to buy the 3.0 Fox bypass. Unless I find a set used for a good buy. I have not seen any for sale yet.
BIOSYN
Mojave Desert
2021 JLUR
I was pretty impressed with the Mojave set up when I test drove it. Told the dealer I wanted to go through some dips to test it out. His response was to direct me to this closed dirt road where I proceeded to test the hydraulic bumps a few times. lol
Ultimately the wife preferred the JL to the JT and here we are. Living in the desert makes me long for hydraulic bumps and bypass shocks.
wingdog
Subaru Crosstrek
For whoever successfully replaced the rear shock upper bushings, how do you get the lip of the bushing going into the eye? I tried to do it with bolt, nut, washers and socket. The lip just did not want to go in and finally teared up ?.
migyb
Miguel
Vancouver, BC
2020 JLU Willys
I cut part of the lip so it fit - and then pressed it in with a quarter and a puller
This looks insanely ghetto, because it is, but it worked, no issues with the shocks after some rough trips.
Jeep Wrangler JL Gladiator Fox shocks on JLUR? IMG_7506
Jeep Wrangler JL Gladiator Fox shocks on JLUR? IMG_7507
wingdog
Subaru Crosstrek
Thanks. This will be my last resort and the lips are wasted anyway. But there must be a better way to do it ? .
Easttnrhino
Tad
Decatur tn
2017 power wagon
Gas Serviceman
I put Jt rubicon fox shocks on our JLU xr and it does ride better on road but seems to bottom easier in front off road but the xr has lowered bump stops. Anybody running the fox shocks off gladiator rubicon seem to agree on bottoming out easier? Thanks
El Zilcho
Max
San Diego
2018 JLU Sport, Rubicon axles
Yes. As I mentioned in my reply somewhere in this thread, love gladiator shocks on road and on dirt roads, but needs more dumping off road.
Easttnrhino
Tad
Decatur tn
2017 power wagon
Gas Serviceman
I had read that, but i thought it was the rears that were soft, but oh well i still got my stock red shocks just really like the road ride of the foxs but bottom out very easy in front, guess you cannot have all huh. Thanks
El Zilcho
Max
San Diego
I guess I was not clear, its both front and rears. I really like mine, as anything else except dropping from ledges is a big improvement. And unfortunately I spend 95% of the time on road. But I can see how this shocks might not be ideal for XR with extralong bumpstops.
Kevin Mojito
Washington
Need to get a set off the Mojave. They just a touch firmer then the JT Rubicon. Bonus they are By-pass shocks. Gets 2 inches at top and 2 inches at bottom of stroke. Goes way firmer at the ends of travel.
Prices have come down since I bought my set.
Jeep Wrangler JL Gladiator Fox shocks on JLUR? MandR
El Zilcho
Max
San Diego
That's actually my plan. I saw a set for a great price, but axles steering and tires are a priority for now.
JLUSDIEM
Diem
sugar land, tx
2021 RUBICON 4xe
has anyone with a 4xe done this? My 4xe hasn't come in yet but have heard that the weight of the battery has made it drive "smoother" compared to a non 4xe
AnnDee4444
'18 JLR 2.0
What are you doing for bump stops?
El Zilcho
Max
San Diego
4XE might be too heavy for gladiator fox shocks. You might feel too floaty because of the weight and not enough valving, but you'll never know unless you try :)
