Fox DSC rears in front?
c20040215
Leon
Any thoughts on the lower front control arm drop brackets, and if they'll influence brake dive in a meaningful way?
Yes. Noticeably less.
El Zilcho
Max
San Diego
2018 JLU Sport, Rubicon axles
My limited understanding says yes, they will help, but I'm not an expert on solid axle vehicle suspension, only starting to learn. I'll wait on comments of more knowledgeable people :)
AnnDee4444
'18 JLR 2.0
Cuz I know you geek out on this stuff:
Thanks for this... I haven't seen the calculator he references before.
Not sure if it's a good idea yet but I have been contemplating drop brackets on my 1/2" lifted JLR, specifically for brake dive. All the brackets are designed for +2" of lift... so if I can find one that relocates the lower arm 2" down it would be like stock Sport control arm angles. Some even have an adjustable upper mount for fine tuning.
Downsides are obvious: it could rub more with my already low ride height. However it might help the 2-door's tendency to want to wheelie up hills, and might also keep from scraping as much going downhill (which is when I scrape the most). And of course the potential on-road improvements.
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
Just sayin…
Jeep Wrangler JL Fox DSC rears in front? 318A8075-61FA-4F09-9A63-D07AD34B3638
Remorseless
NC
Just sayin…
Pros and cons though on the scraping - at least the scraping would be on a cheap/cheap-ish bolted on bracket instead of a bracket welded to the frame, a bracket that could be replaced in an afternoon. But if you're at stock-ish ride height, definitely going to be in that thing often probably.
GATORB8
CLT NC
TX_Ovrlnd
CStat, TX
'22 Zilver JLURD
freethinker
TIL that people believe any front shock with a reservoir must be remote only, and that every non-remote reservoir system are always valved the same. Those same people also put their toilet paper rolls on the wrong way. :facepalm:
CNJLUR4xe
Colton
Alabama
2022 Rubicon 4xe
Bocephus
Virginia
Sam’s Decorative Automotive Button Emporium
The Mount Zion video explains it. We went with the front remote reservoirs first, but the long MC links impacted the hose at flex, and the shop cautioned against it. the shop was in touch with both MC and Fox as we thought through options.
I was concerned of damping / valving differences. Fwiw, As others mentioned…MC puts the same shock at all four corners. These have the adjustable valves. I haven’t messed with them really at all, but I probably will. Middle setting for both dials on all four corners. The suspension feels more taut compared to mushy factory 392 setup. My last jeep had 2.5 Kings remote reservoirs. And so my points of comparison are - standard JLUR, JLUR on Kings and Evo coils, standard 392, and now the 392 on the MC coils and fox 2.5 resis. I’m super happy with it, maybe I don’t what I’m missing. If anything, I could have Accutune valve all four of them for my setup, but I don’t think that’s something I care about at the moment. Fwiw, I tried working with Accutune when setting up my jeep, but they didn’t have much going on for the 392 at the time, especially in my scenario of pairing the MC 3.5 with Fox shocks. I wanted to buy shocks from them, truly could not.
Some test fittings pics with dsc rears up-front. You can see here that more bump pucks are needed.
Jeep Wrangler JL Fox DSC rears in front? 2DFB0356-8FD5-4874-9A10-FC37B2730533
Jeep Wrangler JL Fox DSC rears in front? 027B7212-BA1E-4BFD-8BDD-2BF51EC4AB52
Jeep Wrangler JL Fox DSC rears in front? 1FB9E8EA-D85A-4AE6-91E9-FE5176018543
And flexing it out …
Jeep Wrangler JL Fox DSC rears in front? C99B96CE-DB62-4F70-A5AF-EC0B9F580551
Jeep Wrangler JL Fox DSC rears in front? FA8DF4EB-0CED-4A06-9CB1-94D71B3F81C4
Jeep Wrangler JL Fox DSC rears in front? A53BF78B-AB68-471F-A9A2-A9A8394E8CD2
mt zion did lots for me here. The MC lift and fox shocks, fox front hydro bumps, MC steering and track bars, Woods front and rear shafts, RCV front axle shaft (rear is stock). 4.88 gearing. LOD signature rails. Control arm and shock skids, diff cover and skids.
Just a great shop to work with. Pics and texts and calls throughout everything. I live in Virginia with 5 or 6 shops in proximity, but I drive the 100 miles to Mt Zion and will continue.
I daily drive this and weekend trail it. Need a bellypan before I take it to Rausch Creek probably, but there are trails in the area that I can have fun on without risking my oil pan. I’m 99% sure im going with Artec kit, just saving my nickels.
GATORB8
CLT NC
To prevent adding more bump, may want to consider either fabbing or sourcing the Bilstein remote resi lower brackets. Similiar to the MC's, but move the bottom mount only outward and not upward.
Jeep Wrangler JL Fox DSC rears in front? 1660914372343
GATORB8
CLT NC
I have my own copy of his spreadsheet saved and used it extensively prior to ordering my Accutune fox 2.5s lol I have "3.5-4 lift" shocks on my jeep with only 2" of lift thanks to that spreadsheet lol
Ha, same here.
Bocephus
Virginia
Whew, 19.4 compressed plus the inch or so from the lower shock mounts. Prolly 3" of uptravel and 10" down. With half of the uptravel in the bumps.
I guess it makes complete sense to swap out $3,000 worth of shocks because the $50 MC sway links contact the hose as installed.
a good portion of the uptravel is indeed in the bumps. You only hear / feel a click, and not noticeable at all off-road. id Love more up travel, but I’m not dissatisfied tbh. 392s and XRs have super long bump towers to begin with, limiting travel. I think I gained up travel.
The consideration was that using the piggyback rears up front don’t really sacrifice anything, other than minor valving differences that can be overcome by dialing in the valves, or more dedicated approaches ala Accutune. We did talk about using other sway links, I brought that up, but considered that those long links make use of the full coil, allow max droop. Changing that up seemed more overall impactful than running the piggybacks up front. It was less about 50 dollar links versus 3k shocks.
GATORB8
CLT NC
Apologize for my tone, was more a reaction to the presentation in the MZ video.
Looks like you definitely need the sway length with your crazy current droop.
If you have the fender room to go to 3" of net non-392 bump (~19.25 shock length at bump) by relocating the shock bottom mounts to be level with the stock mounts as I mention above, it may give you back some uptravel, although it'd reduce down travel accordingly. Looks like you may need clearanced fender liners to accomplish that.
