Exact Center
Byrds8
My wife and I just purchased our first pair of Jeeps. So far we love everything except how they steer. IE, a bit of play in the steering and how they like to travel if they hit the edge of the road or rut. I have read that exact center fixes a lot of the things we do not care for. Is this the best option to make the steering not so soft and seemingly liking to go where ever it feels like?
cgkades
Brett
Utah
2021 JLUR, 1997 XJ
One thing I noticed when I got my jeep is that the dealer over inflated the tires and I was just drifting all over the road (I keep mine at about between 35 and 40 now). I'd check that first as the cheapest option for a fix
Byrds8
Byrds8
They are both sitting at 37 which is what the door says to run them at. Granted, in other vehicles, I have always went a bit higher. But since these came with the extreme recon package that included 35s, I left them alone.
GrayWolf.Overland
Subash
Maple Ridge, BC, Canada
www.instagram.com
2025 JLU Rubicon (Anvil Gray)
Fox ATS or Falcon ATS stabilizer should firm up the steering feel. Nevertheless, solid axles front drives differently and there is always some inevitable mild pull based on how the tarmac was sloped.
If you are tracking straight with only one finger on the steering, and there is no dead play on the center - that's perfect by Jeep standards :)
Byrds8
Byrds8
When you say dead play, do you mean where I can move the wheel back and forth but it doesnt move? If that is the case, they both do that. You can move a good bit and it doesnt steer.
Byrds8
Byrds8
So is the exact center not the way to go to firm this up and make it drive better? Are Fox ATS or Falcon ATS stabilizer better than the exact center?
Roky
Roky
I would lower the tire pressure to 32 psi , and get some Mopar lift lower control arms. What you’re describing is likely due to low caster. The EC is a great product, I’m running one myself, but the steering stabilizer isn’t the problem in this case….
azwjowner
Phoenix
Try 28 psi. I suspect Jeep just wants the tire pressure warnings to trigger >=35 psi, which is the minimum official rating for truck tires. Jeeps are much lighter...
Byrds8
Byrds8
So the slop in the steering and it wanting to follow the road etc isn’t due to the stabilizer? I thought that is what it fixes? They don’t seem to want to go back straight after turning either. Unless you help it anyway
Roky
Roky
The EC will help the return to center, but a steering stabilizer isn’t going to help the wandering at highway speeds.
Byrds8
Byrds8
Would the LCAs help? Can the caster not be adjusted without them? What about the play in steering? That normal and nothing to help it?
Roky
Roky
Yes the lcas will help…. When you increase your caster that will make the steering feel a little heavier, and that will make it feel a little firmer…..
There is no adjustment for caster on the factory lcas , the Mopar lcas are longer, and that’s how they increase caster. You can get adjustable lcas instead and that would give you even more adjustability…….
This is what I’d start with along with lowering air pressure. The Mopar lcas are 70 ish dollars, that’s considered inexpensive in the jeep world, where you now reside……;)
Byrds8
Byrds8
I am used to modding. Did my trucks as well as Camaros. Bit by bit little by little. So, sounds like adjustable LCAs and an alignment is the way to go. Would adjusting the caster help with wander also?
Roky
Roky
Yes
