ARB diff cover with Exact Center
KNN
K
Maryland
2020 JLU Sport Diesel
Sell cover…………..?
Is it ever advisable to grind down a diff cover to clear components? I just swapped Clayton track bar for Steer Smarts and now my Yukon Diff cover hits. ??‍♂
I swear this Jeep is never ending.
Jeep Wrangler JL ARB diff cover with Exact Center A336B12F-B8C2-4CA0-98E1-BD89E9039542
Jeep Wrangler JL ARB diff cover with Exact Center 72D5155D-DB88-446A-9832-4F493FD07322
KNN
K
Maryland
@BDinTX to your original question have you tried playing w/ angles to clear the ARB cover? Mine hit at once point but in this current config it seems to work ok.
Jeep Wrangler JL ARB diff cover with Exact Center 75CB69EA-1BB5-4990-848B-E882DE0C7B39
Jeep Wrangler JL ARB diff cover with Exact Center 406D6641-550D-42A5-BE48-E1743A9DE2F7
Roky
Roky
I wouldn’t grind cover……..:stop:
  • Like
Reactions: KNN
BDinTX
BDinTX
Dallas, Tx
With the synergy clamp I don’t believe rotating would help since it’s basically a 1/2” collar and it’s contacting just below the horizontal center.
With the Clayton if I rolled it forwards about 15° there was a spot jest below the top plate that would give about 1/8” clearance. I kinda mangled that clamp getting it off though so don’t really want to put it back on.
I appreciate the suggestion though.
  • Like
Reactions: KNN
Fast-n-Furious
PA
2022 392 XR
Just wanted to post my findings with Fox ATS SS and the Clayton SS relocation bracket. With stock tie rod and drag link, but RuffStuff super beefy diff cover (1/2" ring and 3/8" cap). You can see due to the Clayton bracket moves the SS to the driver side, at full lock of wheel to the driver side, the Fox clamp is really close to the diff cover, if someone on the driver side turns the wheel a bit more it'll make contact to the diff cover for sure. And at full lock to the passenger side, the shaft rod is also getting too close.
Jeep Wrangler JL ARB diff cover with Exact Center IMG_0534
Jeep Wrangler JL ARB diff cover with Exact Center IMG_0532
Jeep Wrangler JL ARB diff cover with Exact Center IMG_0535
I think a few solutions:
1. A new SS track bar mounting bracket that moves the SS to the passenger side a bit. Metalcloak has one but it moves the SS further higher. I prefer the SS to be as level as possible.
2. Aftermarket tie rod that gives it more clearance between the diff cover. But may run into other fitment issues with Fox ATS.
3. Remove the Fox ATS and use a different SS with shorter shock body. Or even back to the factory location and no more SS relocation...
