Dynatrac ball joint snap ring replacement
AnnDee4444
'18 JLR 2.0
Anyone know where to get a replacement snap ring for Dynatrac ball joints, or the exact size/specs? I tried contacting Dynatrac with no response, and It's not the one in their $157 rebuild kit.
I guess I got a little too aggressive with the snap ring pliers and snapped one the wrong way (in half).
chevymitchell
Shawn
Pueblo West, CO
Avi Engineer
There are 3 snap rings for those ball joints.
Do you need the one for the exterior (top joint), the one under the boot that holds it all inside the joint, or the little one that holds the ball joint to the stem?
melendez69
Marc
Waxhaw NC
2018 3.6 JLR / 2013 991 911 / 2013 E92 M3
...huh?
I snapped 2 during install... contacted Dynatrac & they replaced them under warranty. I used a little lube on the replacements & they slid on fine. Corey Jennings was the guy.
It's disappointing to hear they've been non-responsive.
AnnDee4444
AnnDee4444
'18 JLR 2.0
The exterior top joint. It looks like the other two are available in their rebuild kit.
AnnDee4444
AnnDee4444
'18 JLR 2.0
Still have his contact info?
melendez69
Marc
Waxhaw NC
...huh?
chevymitchell
Shawn
Pueblo West, CO
Avi Engineer
Like Marc mentioned, I think your best bet is to go through Dynatrac for a new clip. I haven't had the need to source one so I don't have any specs. Maybe they can give you the spec for it so you can buy it on your own.
AnnDee4444
AnnDee4444
'18 JLR 2.0
Got the replacements ordered free of charge thanks to Dynatrac.
In case anyone is ever searching for this, their part number appears to be JP44-0015-A "SNAP RING, EXTERNAL, 1.50" , YELLOW CHROMATE"
