Oncorhynchus
- Moishe
- Aug 30, 2020
- San Jose, CA
- 2018 JLU Sahara Sting Gray 3.6L
Nothing like trying to out on chains for the first time when you need them. Seen lots of Californians take 30+ minutes attempting to put on their chains.The Rubi's diffs are open when not locked, and running on paved roads "locked" isn't advisable. Wheels need to turn at different speeds when cornering, which is why Jeep programs it so you can't run them locked over a certain speed. On slick roads, running locked will cause tires to lose traction when cornering, not really helpful... This is a situation where I'd prefer an anti-spin rear diff that can lock only when taking off, or if you need to use the throttle to straighten out. The open diffs probably cause me to run 4H in slick conditions more than I actually need to, as I find it easier to straighten out in 4H if one of the axles loses traction.
Chain all 4 wheels for best results, rear axle if you're only carrying one pair. If you're carrying them just to meet the letter of the law, make sure you try them on and know how they work before you need them...in case you actually need them!
if you don’t have bead locks then be careful about airing down too low.
I purchased tire socks instead of chains for my Wrangler. Very expensive but weighs practically nothing and takes up no space. In the Sierras you may find yourself alternating between snow, slush, ice and dry concrete in a span of a few miles. That is why I went with the socks. Easy to take on and off.
