Driving in snow / ice…any tips?
Nole_Dynasty
Seminole
Charlotte, NC
2020 JLUR
Florida boy now living in North Carolina where we are supposed to get a decent amount of snow. Any things I should know or tips for driving in snow or ice in the event it’s needed?
‘20 JLUR / Mopar lift / 35” BFG KM3’s
ConqSoft
Keith
Wake Forest, NC
2020 JL 2 Door Rubicon 6 Speed
Systems Analyst
If you're in Charlotte, you are in for more of an ice event instead of snow. Best bet is to stay home. We don't have the equipment here to keep the roads in good shape.
TheBirdie72
Rhode Island
2021 Jeep Wrangler Freedom Edition 2 Door
New Englander here…
Don’t go faster than is safe for conditions, and allow plenty of following distance!
Especially that last one! People seem to suddenly forget how to use their brakes properly when roads get bad. Always give yourself more time to react!
Shibadog
Bowling Green, Ky
2020 Wrangler Sport S hardtop
Remember in snow 4H is your friend, however while you can accelerate easier than the guy without it your stopping distance will be the same as the 2wd folks. Lots of folks in 4wd/awd get in trouble because they think since they’ve got more ”go” they also have more ”whoa”- a serious mistake. For ice, nothing but chains or a true winter tire (Blizzak or similar) will make a lot of difference. If you can, stay home when it’s icy, if not, takes things VERY easy-everything in slow motion and gently.
aldo98229
Aldo
Bellingham, WA
Market Research
Remember: 4WD gets you going, it don’t get you stopping. Drive slowly.
If you don’t feel comfortable, stay home.
Blanco802
Ben
Vermont
Jeep Wrangler
As others have said, tires play an important role in winter driving conditions. 4H can help you initiate better traction to get you going, but it won't really help you in trying to stop. For that reason, maintain a safe distance between yourself and the car in front. Also, when throttling, don't punch it as it increases the likelihood your tires will spin and lose traction. Slow and steady is best.
macintux
Indianapolis, IN
2005 LJR, 2022 JLR
If you get a fair bit of ice and there's an empty parking lot nearby, take advantage of it and go practice. Nothing prepares you for that first uncontrolled spin on ice, better to have it in a controlled situation than on the interstate (been there, done that).
cornercanyon
bruce
Texas Hill Country
2014 JKUR, 2021 JLUR XR
. . . realizing each day–
Find a safe place to learn away from traffic and obstacles. We "learned" how to drive in snow by going out early, early, early Sunday mornings to the wide open mall or large unplowed parking lots. Try stopping and starting using different weight on the pedals. Trust your anti-lock brakes to tap faster then you can, just hold the pedal. Once you are comfortable and if it is safe to do so; take turns at different speeds to feel when your vehicle begins to get sloppy. The only way to learn how to drive in the slop is to go drive it. Just don't learn in traffic–
edit: not ice. Ice = bad, even with studded snow tires. Stay away from ice, if possible. Snow is always managable until about fording depth, ice can be wicked–
JoeBanks
PA
2021 Willys Sport JLU
Do you have automatic or manual transmission?
Engine braking is helpful when your tires slip on ice/snow. That’s one of many reasons why I prefer manual over auto.
JasonInDLH
Jason
MN
21 JLUR, 15 Yukon Denali
I’d Rather Talk Jeep’s!
Change your tires first and foremost. You’ll get no traction with those. Find a dedicated snow tire or acceptable all terrain with severe snow rating (Duratrac, KO2’s, etc). I always take ESC offline by pressing traction control for a few seconds as well so you can spin your tires.
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
Service
manual control of the auto transmission is faster and more precise than a manual transmission, and doesn’t ever explode.
LuvHydro
Midwest
21 JLUS Hella , 22 JLUSS Hydro
We just got a dose of snow. Last week it was ice.
The best thing to do is assume everyone else that is out is a moron. That's the way they are here anyway.
Driving too fast for conditions, tailgating, sliding into others, sliding in the ditch, on their phones, smoking their blunts, etc.
Until I got my Jeep, I drove a 2WD pickup (really 1WD cuz no positrack) that weighs nothing in the back.
I got around fine in the snow/ice because:
• I'm not a moron
• I slick-test when I enter a road & occasionally thereafter
• I look AHEAD and form a plan
• I use momentum for slick hills
• I start decelerating way before the stop
• Mostly I devote the proper attention to driving in adverse conditions one should.
It's not rocket science, but experience and common sense will help. 🙂
