Differential oil change
CenTX JPR
Central TX
2018 JLUR, 05 TJR 6spd
for the front, the manual states 15ft lbs, then 20 degrees more. isn't that tty?
for the rear, the manual states 30ft lbs with NEW bolts.
now this is from 2021 since there doesn't seem to be one for newer wrangler/gladiators.
the front scares me because some of those bolts are hard to get to and breaking one off and extracting would be difficult or impossible without removing susp parts. That's a pandoras box.
Out of all the guys that have potted their sensors (sensor thread), I don't recall anyone breaking bolts, or replacing bolts. So it's nothing to worry about, and a simple job.
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
I did a diff cover and diff skid when I potted my sensor. It came with longer bolts to accommodate the thicker flange and skid.
I most likely would have reused factory bolts otherwise.
BRuby
Skiing or Snowboarding
JLUR Benz Porsche-M Subie-M
yes, this hasn't changed since 2021 at least.
this is what bugs me. trying to figure out what "good enough" is for the bolts. Error one way you get a leak. the other, you snap a bolt.
i hear you on the "Indeed the rear M220 torque specs show that the bolts should be replaced after one use. Clearly it's an error" part, but why is it clear that it's an error?
the front is 15 ft lbs and then 20 degrees more oomph.so id guess that is around 20 ft lbs or so. i don't have an angle torque wrench. i'd say i know what 45 is and 20 is a hair less than half of that. I'd probably either buy an angle torque wrench or just go 15 ftlbs and a hair more.
i like KISS.
still favoring extracting but i have a year to decide.
You mentioned earlier that you are scared. No need to be scared. Just be careful to crack each bolt off by hand to minimize torque. Front and rear single use. If super concerned just buy new bolts.
When I removed the OEM bolts to pot the locker sensors - the bolts surprisingly seemed on much tighter than the expected for 20 and 30.
Did the front first by jacking up the frame to get clear access. Loosened each bolt by cracking off the initial OEM tightening bite by hand to make sure nothing snapped. Then removed the rest of the way by hand which took way longer than expected. The bolts were very "sticky" and gummed up in the threads. This slowed progress a lot.
The rear also jacked up the frame to get clear access. Loosened each bolt by cracking off the initial OEM tightening bite by hand to make sure nothing snapped. Then removed the rest of the way with an impact gun. This speeded up the process tremendously.
Cleaned off the bolt threads before re-installing them - and they all went back in smoothly and easily.
Do not recall exactly but think tightened to an estimated 20 for front and 20 for rear. Thinking was to see if 20 was plenty and it was. The reusable gasket was stuck to the axle housing so just left it there. As did not want to mess with the leak free orientation. Thought was - could always tighten the rear more if any drips appeared. But none have.
Followed the recommended bolt tightening pattern and all is good. Gasket sealed perfectly.
Used the same bolts in the same holes. They seemed not tight at 20 but are plenty tight. Expect removal to be a snap whenever the covers need to come off again. As a real maintenance item is to clean off the metal shaving fragments off the locker sensor and base housing.
If your lockers do not engage the instant you push. Would check for metal stuck to the magnets.
Is not as simple as draining your engine oil as you have to fill lying on the ground. Otherwise would recommend pulling off the covers to see the status inside and clean away metal stuck to the magnets. Cover takes a lot longer by hand the first time - so use a gun after cracking. Second time should be very easy.
Jeep Wrangler JL Differential oil change 60907F4E-0297-47BA-A1F6-CF90EF8CF2E6
Jeep Wrangler JL Differential oil change ED881606-E558-49ED-A79A-235D83B94091
  • Like
Reactions: zyt
Newbalewb
2008 Wrangler X
Fatbob Frank
Frank
N.E. Iowa
2024 Wrangler Willys
Lab Tech
I went with Amsoil Severe Gear 75w140 in the rear and 75w110 in the front (and the balance of the second pack of 75w140)
3 quarts was exactly the right amount...
Jeep Wrangler JL Differential oil change Diff
I also torqued to 20ft/lbs as it seemed plenty...
kdiff
Kurtis
Castle Rock, CO
392 Rubicon, Sprinter
WannFly
Priyo
Atlanta
2021 Rubicon 4Xe, 2026 MOAB
Cyber security
@Rhinebeck01 or @CarbonSteel
I am need of a little suggestion.
1. I know not to spray brakecleen in the housing, is there something I CAN spray to clean it out? While opening the diff cover, some dried mud fell inside the housing, I used a shop towel to get most of it out, but unsure if there are some crud inside somewhere.
2. I will be putting in AEV diff cover, and also working on a 2.5 inch lift. From what I understand, due to the lift and the pinion angle it might be a good idea to use a little more oil. The question is how much is little more? Right now I cant fill, the jeep front end is open and is on a jack stand under the frame. AEV says to fill fluid until it starts draining out from the magnet hole, but right now due to the angle the Jeep is sitting, it won't work. So, I will do it when the Jeep is at its ride height.
I will be using Valvoline -140 in both diffs.
Another observation - I was under the impression that front fluid should be little better than the rear. In my case, both fluid is same crap. 16k miles, over 3 years, offroad mostly 4-high, at times 4-low, may have used the lockers 2-3 times.
Pic of front, got about 30 oz out
Jeep Wrangler JL Differential oil change 1748733661955-34
Pic of rear fluid (got about 45 oz out)
Jeep Wrangler JL Differential oil change 1748733693614-01
jadmt
jeff
montana
I can tell you AEV sprays brake cleaner in the diffs when cleaning them out (they borrowed my Power wagon to test the covers and gave me covers for letting them use my truck the benefit of living next to their R&D) and I watched them do the test fit)...I also measured mine when I installed my AEV covers and they actually took slightly less than I got out before coming out the hole..I went ahead and put the plug back in and added the amount I had gotten out. it was not much..
Jeep Wrangler JL Differential oil change IMG_20201008_131329057
Jeep Wrangler JL Differential oil change IMG_20201008_145627296
CarbonSteel
I would just wipe it out with towels. Brake cleaner can attack the seals and lead to leaks over time. The worst one to have a leak is the pinion seal given the work it requires to replace it.
Top off the fluids before driving it when the Jeep is on the ground, it will be fine.
Mineral spirits, a.k.a. stoddard solvent. Make sure to dry it out and lube stuff before you close it up.
Jammer
Ft worth
Bright white JL Rubicon
I have 42,000 miles on my 2018 JL Rubicon. Friend of mine we just did the drain and refill it I don't really drive it hard the front because I don't really go in four wheel drive that much it's probably okay for another 20,000 miles what do you think ? 20,000 more on the front and on the rear just draining and refilling is probably okay or should we have took in the cover off I mean it's kind of late now I just had them drain and refill it with new oil but what do y'all think at 42,000 miles ?
mwilk012
2018 Ocean Blue JLU Rubicon
Service
There’s no need to open the cover.
Jammer
Ft worth
Should it had been flushed instead ? If not when should I do it again and i wander how much is left in there by not flushing it vs just draining it ?
