DEF Usage
2020 Diesel JL
Peter
Debary FL
1955 CJ3B Diesel, 2018 Camaro Hot Wheels Convertible, 2018 Dodge 3500 Diesel, 2020 Harley CVO Tri Glide White, 2020 Harley CVO Tri Glide Black, 2020 Jeep Wrangler Rubicon Diesel
General Manager / Owner of CraneWorks Orlando
I had heaters fail on me leaving me on the said of the road in the winter before not fun let's hope the JL comes with a better heater then my peterbuilt and Freightliner.
Is your JL Bikini Pearl? That's the color I ordered. I understand the derate in cold weather but if the temp is above 32 they should not derate the engine. The heater system is not needed for emissions at that temp.
Melny67
Melvin
Staten island
Jeep jlu
Yeah I originally wanted to get stingray but everyone has that color near me. Well let's hope it's reliable I don't do much wheeling hanse the sport s. But if you do a lot of wheeling the 3.0 is a beast congratulation.
JLURD
Alaska
2018 Compass Latitude 6MT, 2020 JLUR 3.0
I got a chance to bring my 3.0 back to the dealer for the fuel and DEF we didn’t have time to put in the day of delivery. It took 2 gallons of DEF and probably would have taken more but we chose not to push it based on the meter showing 2/3-3/4 full. That was after 44 factory test miles and 7 miles driving it to the dealer.
WXman
Central Kentucky
My '20 Ram has been through 1/4 tank of DEF in 200 miles. Ouch.
lightsout
PNW
DEF freezes at 12 deg fahrenheit, The DEF system has heaters in the tank and all fluid lines. During cold weather the DEF system is not used until the DEF is warmed up by these heaters so it will never shut a motor down because its frozen. It will if the heater circuit fails even if it's 100 deg outside. That is a system that I think they could program differently. Living in Fl you would think a check engine light would be fine since the DEF is not and could not freeze but nope it will shut the truck down.
DEF consumption is based on outside temperature, load and driving habits. Pull a trailer in the cold and you will use 4 times the DEF as running around with no trailer and warm temps. Come summer you will think there is something wrong with your DEF system because the level will seem to never move off full.
If your DEF freezes it will cause the emgine to go into "LIMP" mode with a max of 5 mph. This is also why you do not fill to the top of the fill tub as there is NO heating there.
Megatron JLU
Anibal
TX
2020 JLUR 3.0 T Diesel
So only 549 miles and this much usage, it's safe to say it's not lasting 10k.
Jeep Wrangler JL DEF Usage 85C13B2A-DE54-4381-9997-C3A995B06102
Jeep Wrangler JL DEF Usage D2EADDEA-9CDA-42B4-A1EE-D0EB4C40FAAC
BuffaloBill
WI
2024 Wrangler 2.0, 2020 wrangler 3.0
Gosh, I’d have to say something is wrong. I use about 1gal/1000-1200 miles on my 2014 Ram Ecodiesel.
Megatron JLU
Anibal
TX
I wonder if having a heavy foot counts as something is wrong? Lol
Andy-jr.
Andy
Maryland
2012 White JKU, 2012 Black JK 2018 White Grand Cherokee, 2001 TJ, 2020 JLUR EcoDiesel
When I picked mine up from the dealership the DEF was not full, it was about 3/4 by the gauge. I'll wait for it to get low and then track it from the fill I give it.
Megatron JLU
Anibal
TX
Was it topped off at delivery? Not per the gauge but per a person actually filling it.
I'm not sure if it was, I'm just going off what it went through the last 549 miles.
