AVGeek99
- Chris
- Aug 24, 2021
- Peyton, CO
- 2025 JLUR '41, 2024 Rubicon 4xe (wife's) Bright White
- Build Thread
- Link
In early November I had a MC 3.5 GC lift. At that point I had 42k miles on my stock Rubi suspension. I had 35s since day one and in all those miles I never had a hint of shimmy, DW, or any sort of steering issues.
Imediately after getting my Jeep back I started noticing steering issues. The Jeep would wander, especially on uneven surfaces. On sharper bumps there was a shimmy in the steering; on a couple occasions in the first few days this evolved into death wobble. Prior to this I had heard of DW, but never experienced it, now I had. I also had never felt a shimmy in the steering quite like that. I continued to drive it to work that week and there was no more DW and the more I drove it, it seemed like the shimmy was going away, or wasn't as bad so I just lived with it. By mid November the only thing that continued to really bother me was the wandering or flightiness, but after continued driving it bothered me less and less.
It should be noted that all of my driving since having the lift installed has been around home and on my daily commute to work and back. All roads I have driven are hard surface roads that I am very familiar with and have been driving for years. I've not done any off-roading
since the lift.
My plan was/is to get new tires (37s) sometime in March. Before that I wanted to make upgrades that I knew were needed if going to 37s. I was/am hoping to have the shimmy and DW solved before getting the 37s. So after the new year I started working on it. Here is what I've done up to now and the results.
Does anyone else have any suggestions?
- Checked torque (did not loosen first) on all front suspension and steering parts. The driver side LCA was a bit under torqued at the frame. I torqued to 190 ft/lbs.
- This had no impact.
- I measured caster and discovered it was only 1.8 degrees. I lengthened the LCAs and caster is now 6.2 degrees. While doing this I retorqued (after first loosening) all connections on front suspension steering parts. After loosening and prior to retorqing I got on the front bumper and jumped up and down to try to get everything to settle. This same day I also checked my toe alignment. It was toed in 1/16th to 1/8. This seemed to be within recommended spec so I left as is.
- Adjusting the caster fixed the wandering/flightyness but did nothing for the shimmy/DW issue
- The following week I installed 9/16" trackbar bolts in the front. These are a bit larger than the stock 14mm bolts and are intended to reduce play in the trackbar connections.
- This got rid of the shimmy for a week and for that week I thought I had solved my problems.
- A week later the shimmy came back and I had my first episode of DW in quite a while
- The next week I installed all new steering components. These were all part of my orignal upgrade plan.
- SS Yeti Tie Rod
- Toe in is 1/16th
- SS Yeti Drag link with Griffen attenuator
- SS Steering Stabilizer
- All of this had no impact on shimmy
- SS Yeti Tie Rod
- After all the steering components had no impact I ordered and installed (this past Thursday) the SS sector shaft brace. This was not part of my original upgrade plan, but hoped it would fix the shimmy.
- From what I can tell I think this fixed the shimmy, HOWEVER, it brought back the DW in a big way.
- Now when I hit bumps that previously caused a bad shimmy, there is no shimmy and it goes straight to DW. On smaller bumps that would cause a noticeable, but not bad shimmy, the steering is now tight.
- The sector shaft brace is intended to reduce the flex in the steering box on the steering nut where the pitman arm is connected.
- Since the shimmy is gone, but DW happens on the sharper bumps that would previously just induce a bad shimmy for a second, I think the flex in the steering box was absorbing some of the energy of the sharp bumps leading to the bad shimmy. Now with the sector shaft brace the flex in the steering box is now gone so the energy is fully deflected back into the rest of the suspension, which then causes the DW.
- This is purely a theory, but based on the fact that the day after installation of the brace, on smaller bumps that just the day (and many weeks) before consistently caused a minor but noticeable shimmy, now the steering is tight. But on larger, sharper bumps, that had been causing a bad shimmy (very occasionally DW), now go straight to DW.
- Balanced tires. I'm getting new tires anyway, so I've thought what's the point? Besides, on smooth surfaces the steering is tight up to 75mph and beyond. In my experience, out of balance tires, almost always cause some amount of vibration and if bad enough will cause enough vibration that will cause the driver to only drive so fast.
- Rear suspension. I've not even looked at it or retorqued the connections. I doubt this is the cause of my DW, but I should probably do this.
- Ball Joints. These are also on my upgrade plan, but wanted to get the most out of the stock joints as I can. I've not focused here yet because my past experience with bad ball joints, including the JK I had prior to getting my JL, is that they will induce regular vibration, even on perfectly smooth surfaces. Also, with bad ball joints in my JK, driving the same roads I drive now, I never once had any DW. With my JL, even now if i'm on a relatively smooth surface the steering is nice and tight even beyond 75mph.
