CB radios
Warhawk
Curtis
Mount Washington, KY
Sting Gray JLUR
Data Engineer / Application Developer
Are CB radios really dying tech on the trails? That is all I knew for the longest time until this JL. Then reading forums and I am wondering if I wasted money on my CB ?.
Side note: Is there a GMRS that is like the Cobra 75 where I can mount the guts somewhere hidden?
TX_Ovrlnd
CStat, TX
'22 Zilver JLURD
freethinker
Yes their limited range and capability put them out when compared to GMRS. Check out the Wouxun KG-1000G.
Philly_
Dallas / Detroit / NYC
2022 JL Rubicon
You’re right. Not a lot of people running CB’s these days. Mostly GMRS or HAM.
Checkout the Midland MXT275. All the controls are on the mic so you can hide the radio under the dash or somewhere else creative.
You can also get a pair of Midland handhelds for around $100. I have the MXT275 as well as handhelds to loan out to beginners or people who don’t run GMRS.
Rustynail11
Mansfield, TX
2022 Wrangler JLU Rubicon
I have the Baofeng UV-9g handheld with the external handheld mic and a device holder that mounts to the grab handle. I leave the mount on the grab handle but take the handheld out when not in use
Warhawk
Warhawk
Curtis
Sting Gray JLUR
that looks just like what I would want. Is that what you run? GMRS is new to me ?.
Warhawk
Warhawk
Curtis
Sting Gray JLUR
I'm running the MXT275 and have had no issues in 2 years. Mounted behind the glove box and handheld is by the passenger grab bar.
do you know if there would be any issues having a CB ran in the same spot as GMRS? I have a Cobra 75 mounted behind the glove box and would like to have the GMRS similar.
Philly_
2022 JL Rubicon
Yup! Did a huge write up here in my build thread if you want all the details. It’s a little wordy, but I attached a video I based my install off of so you can watch that as well.
I did end up with a different mic mount, though, after the Midland one failed a couple times. Posted about that here.
And here’s a few pics!
Jeep Wrangler JL CB radios 1663555584557
Jeep Wrangler JL CB radios 1663555642661
Jeep Wrangler JL CB radios 1663555668806
Warhawk
Warhawk
Curtis
Sting Gray JLUR
That’s just like my CB.
The only thing I don’t like is that most GMRS antennas I have seen have been ran to the drivers side cowl area. Seems to be a bad area to me…I am not sure how it compares to a CB antenna.
Philly_
2022 JL Rubicon
It’s actually a great spot for it as the hood is a good ground plane. I’m not a fan of that location either so I used a tailgate mount from CoolTech and mounted my antenna in the rear. Write up is also here in my build thread. ;)
I’ve since flipped the mount to clear 33’s and 35’s on the Teraflex Alpha HD hinge reinforcement and tire carrier, but it works great upside down as well. When I ultimately go to 37’s, I will likely have to take my die grinder to it for a little extra clearance, or do a full relocation.
Jeep Wrangler JL CB radios 1663557827395
Jeep Wrangler JL CB radios 1663557856302
Jeep Wrangler JL CB radios 1663557919847
Jeep Wrangler JL CB radios 1663557953567
old mike
mike
in the west
little red 2021 JLR (Ruby J. L. Tudor)
wcjeep
Earth
YJ with stuff. JL 2dr Sport
Still turn on the CB for those that choose not to upgrade. Running a Midland gmrs in the Jeep. Also carry water proof Baefeng gmrs radios when out of the vehicle. Running a Yaesu ham radio for long distance communication. Lastly Running a cellphone booster. Gmrs sees the highest usage.
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
The MXT275 fits nicely behind the panel under the steering wheel and does everything I need. Mounted with these Velcro strips: https://a.co/d/9l3xByi
I thought about getting the MXT575, but it's significantly larger and I was concerned about where I'd mount it. Some people mount that one under the passenger seat. That spot, however, is taken by an Epic Kraken.
2mnycars
Canada
JLUR
Great posts. Thanks for the suggestions.
DaveL--first CB I used was back in "75 in my Ford 1/2 ton.
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
There are no truly good spots to mount an antenna on a Jeep. At least from an antenna performance standpoint.
