DaltonGang
- Sep 29, 2018
- Doesn't Play Well With Others
- 2018 Wrangler JLU Sport S, Rubicon Suspension, Rims. Firecracker Red
Corrosion with dissimilar metals is a common concern on sailboat masts, but is easily addressed. Stainless steel screws and rivets are frequently used to attach equipment to the mast. This is always done by isolating the 2 metals from each other. When a steel machine screw needs to thread into an aluminum mast, a product called Tef Gel is used. It is a paste that is brushed completely onto the steel threads and into the threaded hole before screwing into the aluminum. This isolates the two metals from each other by not allowing electrolytes between the 2 surfaces, preventing the galvanic cell from forming and thereby preventing corrosion. My sailboat has multiple steel screws and rivets in its painted aluminum mast with zero corrosion after 20 years of salt spray from ocean sailing. Tef Gel is sold at West Marine and on Amazon. It is important to note that an unpainted area of aluminum adjacent to a painted area (like under the door hinge) will be almost guaranteed to start the corrosion process at the edge of the paint and work its way under the paint. Aluminum should never be left just partially painted.
This looks like a must, when repainting, or taking the hinges apart.
