Beadlock fail at SEMA causes broken leg
Sublime
Sublime
Tom
Farmington, MN
2021 HellaYella Rubicon
I mean yeah... anything can be dangerous. But how often does/has this actually happened? Kinda comes off as a warning from some "get off my lawn" type that waited 40 years for an incident to occur just to finally say "I TOLD YOU SO!"
Sucks that it happened, but in reality, most likely a complete non-issue.
I didn't intend this as an "I told you so." If you took it that way I apologize.
jellis4148
Missouri
I check the torque of my Beadlocks every 3 months. It physically only takes about 10-15 minutes to go around with my torque wrench.
Deleted member 74991
Guest
Since beadlocks get discussed here once in awhile. They remind me of when I used to work on truck tires back in the 80s and knew how dangerous split rims could be. Beadlocks seem to not be treated as if they're potentially dangerous. The amount of pain must've been excruciating.
The Title is misleading. It should read “Another Bronco Owner Fail.” Or “ Built Ford Tough.”
In all seriousness hopefully there isn’t any permanent damage and everything can heal.
txj2go
DFW
Something is not right about this story. We need to know more details. I can't believe that that many bolts failed simultaneously. Just not happening with normal tire pressures.
The ring laying on the ground appears to be deformed like a potato chip. I suspect that a few bolts on one side failed first and then the failure unzipped around the perimeter.
Gorilla57
Chandler AZ
2019 JLUR Mojito
Creeker
Hickory, NC
CJ-7, 2020 JLR
Condolences to those that were injured.
One item that is often overlooked is there are three torque specs for bolts.
  • Plain and Dry Conditions (e.g., 5/16" , Grade 8 Bolt = 24.5 Ft*Lbs)
  • Zinc Plated and Dry Conditions (e.g., 5/16" , Grade 8 Bolt = 20.9 Ft*Lbs)
  • Lubricated (e.g., wetted with anti-seize 5/16" Grade 8 Bolt = 18.4 Ft*Lbs)
From first hand experience, a wetted 5/16" grade 8 bolt will break with ~25.4 Lbs
Reference:
https://www.fastenal.com/content/feds/pdf/Torque-Tension Chart for A307 Gr5 Gr8 Gr9.pdf
Jeep Wrangler JL Beadlock fail at SEMA causes broken leg Torque-Tension Chart for Bolts A307 Gr5 Gr8 Gr9 M
Sometimes, the instructions are not very clear as to the proper torque spec.
Jeep Wrangler JL Beadlock fail at SEMA causes broken leg Dirty-Life-Beadlock-Wheel-Install-Instructions_0 M
Reference:
https://www.quadratec.com/sites/def...ife-Beadlock-Wheel-Install-Instructions_0.pdf
IMHO, I find these instructions do not provide enough details regarding which torque spec to use on the 5/16" bolts especially when using a wetting agent like anti-seize.
Since most folks use anti-seize and grade 8 bolts with zinc plating when installing bead locks, it is possible that the incorrect amount of torque was applied to the bolts (i.e., like the 24 Ft*Lbs detailed in the instructions above). If the amount of torque did not match the conditions of which the bead lock rim was installed, the bolts may have been fatigued. If the bolts were fatigued and/or if tires were filled with too much air (i.e., above 40 PSI), this could have been a reason(s) for the incident to occur.
Oh, almost forgot, how many of us use a calibrated torque wrench and that calibration has not expired.
rkwfxd
Rich
Whittier
Unemployed
I’ll never believe that all 24+ Bolts on a properly installed beadlock ALL broke at the same time while trying to hold 30-35 psi. This accident was 100% human error IMO.
KoKo
Karim
2022 Jeep Wrangler Unlimited Rubicon Diesel
I mean, beadlocks clearly make a lot of sense off-road and they are awesome. Traditional beadlocks do come with a potential for catastrophic failure. I like the new concepts folks are coming out with that would not catastrophically fail, just let the air out.
First that comes to mind is Icon's Rebound pro
Speaking of which, I'm about to mount some 37x12.50 R17 Ridge Grapplers on my Rebound Pros tomorrow... Happy to report how that goes :) if anyone is interested
Mx5red
Paul
San Diego
2020 JTR, 2020 JLUR
Reference:
Reference:
I feel like I’ve ugga-dugga’d small bolts well past that on a regular basis?
The bottom line is: any kind of speculation from these pix is just that; speculation.
I guess speculation is fun, because we all do it. Myself included.
I'm going with over pressure. You know, those clamp on air chucks and portable compressors. Turn it on and go do something else, then come back at the wrong time.
One thing positive this event does, is give us all pause to think about the forces involved with a tire.
jellis4148
Missouri
I have KMC Tank wheels. Nobody has ever said not to rertorque, but that doesn’t mean I’m not wrong.
I think the Trail Ready recommendation, to change the bolts that lose torque, is to address the potential of bolt(s) fatiguing or yielding (stretch).
