MacJack
- -O)|||||(O-Jack
- Aug 9, 2018
- Western NC
- 2018 Rubicon JL 2 Door
- Vehicle Showcase
- 1
OK good write up and photos you’re in the club now. I like your location for the reasons you gave. I just wanted to hide mine more.I finally took some photos. I still need to adjust the aim of the lights a bit, but they made a huge difference. I need to turn them outboard a hair more to light up the sides more even with them poorly aimed I can see much better to back up. Looking at the light output the single row house may have been sufficient rather than the double row, but the extra light will be nice when I'm backing while in the woods.
Heck for $20 lights, they're brighter and cast a nicer beam than I expected.
The stock lights are so weak, that the brake lights are pretty much the only thing lighting up the area behind you.
With the new lights added, the dull red is replaced with a nicely lit view of everything. As you can see, the beams meet near the center, so I'm going to push them out a bit to light a little more of the roadside. No sense in overlapping the lights too much, but I'm not playing with the aim of lights when it's hovering around single digit temps. Till I adjust them though, this is still a huge improvement.
And then one shot of the actual lights on my bumper. They're away from debris kicked up by the tires, and not in the way of anything. No risk if getting damaged if I get into some deep stuff off road either. And bright enough, that even during daylight with snow on the ground the camera still picks up the shine.
