Auto Start/Stop ! Light on
melodyp72
melody
2018 Jeep Wrangler JL
EDIT: had an appointment with Jeep and it was much worse than I thought. Had a major oil leak that wasn’t detected and it was leaking somehow onto some O2 sensors which was misfiring a lot of stuff. They quoted me $4500 to fix so we ended up trading for a new Jeep end of story.
2018 wrangler JL auto start/stop light with (!) Came on along with check engine light. Checked the batteries and replaced the auxiliary battery.
Drives very sluggish. Scared to drive it…can’t get into Jeep until Thursday. What could be failing???
SW Florida.
Pic for attention.
Jeep Wrangler JL Auto Start/Stop ! Light on IMG_7814
mwilk012
2018 Ocean Blue JLU Rubicon
Service
The auto start stop light is irrelevant, it comes on with any other related system failure, in this case the check engine light. The engine fault needs to be diagnosed. We’d need more information to be of any help at all.
The Last Cowboy
San Antonio, TX
2020 JL Willys 2 door
When one battery goes bad, both are actually bad and they should be replaced at the same time. Ideally you should eliminate the aux battery, then replace the main battery with a group 94R/H7 battery.
The process to eliminate the aux from the circuit is simple, and a common mod among the members here. I got so determined last time that it happened that I completely removed the aux and rerouted the power wires on the PDC.
Terrymo
Terry
2023 JLURXR 3.6 ET
Get it scanned for diagnostic trouble codes and report back for better answers. Otherwise people are givung you best guesses. So…tell me about those headlight covers.
melodyp72
melodyp72
melody
Wow thanks. Hopefully it’s just a battery issue then.
melodyp72
melodyp72
melody
lol you like? Had to have them.
Terrymo
Terry
2023 JLURXR 3.6 ET
Not my thing but I’m just nosey in general. 🙂
@mwilk012 does this for a living. You can trust his advice
hoch
Hoch
UT
2018 JLUR 6-sp
Well, just pull the fuse and neg cable real quick and see if that’s the issue. Check for loose grounds as well.
mwilk012
Service
1. Oil leak from valve cover onto oxygen sensor
2. Blown head gasket.
3. Stuck open EGR valve.
4. Failed ignition coil.
5. Clogged cam phaser / oil control valve.
6. Rodent damaged wiring.
Put em all on a die, and roll it. You’ll get about that close without more info.
If your check engine light is on, there are codes. Whoever tried to read yours was using a low quality scan tool that couldn’t get past the secure gateway. Try an Oreilly or NAPA store if that was an autozone.
melodyp72
melodyp72
melody
Thanks
jeepoch
Jay
Longmont, CO
@melodyp72
Use your cluster's Electronic Vehicle Information Center (EVIC) display. Arrow down, from the left side steering wheel buttons, to the 'Stored Messages' page. Any detected codes from a Malfunction Indicator Light (MIL), which is the Check Engine symbol, will tell you without needing to plug in a diagnostic tool.
If your Check Engine symbol is illuminated, you will have a stored message. If not, that's an Engine Control Module (ECM) software bug. Likely not, I used to write Engine Controller software for Chysler several years back. Diagnostic codes are typically some of the most tested feature sets.
Good luck,
Jay
