zouch
- Sep 17, 2020
- Berkeley, CA
- XJ, JLUWD
37" KM3s here, on a mildly built/armored diesel.
i find that if i don't want to see my Hot pressure climbing more than ~10% (indicating undue sidewall flex generating heat) they need to be in the 33-35PSI range cold, and that's been working well for me. not seeing any significant wear in the center vs the edges (but it's really hard to tell when we factor in the wear from off-pavement use with pressures in the sub-teens).
granted, the KM3s have an unusually narrow tread face making for a narrower contact patch which means they're already further over on the casing in a turn, but i hate the mushiness of an underinflated tire, especially in anything like an Emergency braking/avoidance maneuver.
i find talk of the "Chalk Test" interesting; unless people are going out and throwing their J**ps around at speed to simulate actual driving conditions, chalking tires isn't going to tell you anything especially useful; i think it's leading to a lot of underinflated tires.
for perspective; in Autocrossing, we would do a similar test (using white shoe polish, usually) to see how far *above* rated pressures we needed to inflate to keep tires off of the sidewalls.
Just curious what others are running for air pressure on road with 37s.
I did the chalk method and I'm down to 26 pounds front and rear. This is my first time doing the pressure this way, so curious what others are running.
My tires are
General Grabber X3 37/12.50R17 on method 105 beadlocks.
