I heard great reviews for AEV stabilizer which is a pressurized shock vs the Terraflex which is a neutral thru-shaft design shock. Which would you guys go with?
I can't speak for those, but I did originally try a Fox pressurized stablizer, and it made my Jeep pull to the right. Swapped for a Fox ATS through shaft and it's been great- would recommend that design for sure.
I'm running the aev one and it made a nice improvement over the stock one after the lift. I looked at relocating it but I figured for the price I can afford to replace it a couple times if I end up hitting it on something.
I have a falcon 2.2 on mine. If you're interested in drinking some of the roadmaster coolaid I'll let you test the 140#er I never got around to installing. I think I have a bracket for an oversized tie rod tho.
I have the 2.2 fast adjust. I have to say it was quite pricey. Do I think it was worth $400? Probably not, but I do enjoy the difference it made to highway driving and the soft setting is great for putting around town or off-roading!
