Fox ATS or Teraflex Falcon 2.2 stabilizer?
Eischman
Eischman
Kevin
Hortonville, WI
2021 Rubicon Unlimited
Discount tires just mounted them 2 weeks ago and said they inflated them to what the tag says inside the driver door, I’ll check that, If I remember right it’s 37psi (I have the C load range)
Yep, were more like just under 40.
Roky
Roky
Ok just watched video and he used the Synergy Relocation Steering Stabilizer to move Fox SS up on the bar above it. It looked like he used a different bolt to attach it to the tie rod. He didn't use the same bolt he pulled from tie rod ??????? It was not the Fox 2.0 ATS it was just the normal Fox SS.
OK just watched 2nd one for the Fox 2.0 ATS and he put his on opposite the first guy. The first guy put the base (bottom) to the right and the 2nd 2.0 guy put base(bottom) to the left toward shock. Why the 2 different ways?????
I’m not sure, but it either goes like yours is which connects to the tie rod by the wheel, and connects to the axle in the middle. When you relocate it, now it’s connected to axle on a replacement track bar bolt and connects to the tie rod in the middle like this….
Jeep Wrangler JL Fox ATS or Teraflex Falcon 2.2 stabilizer? 0450D832-0A48-4604-AFAF-CDA8946288CB
NewJLU2019
Curtis
2021 Rubicon Unlimited 2019 Sahara Unlimited
Did you hear that WHOOOSING sound. My head was under it. I see the Fox SS 2.0 ATS has its on bracket that moves it like you used it for the Roadmaster you have now. So when I do break down and get 37's I should get the Fox 2.0 ATS not the TS like this video?
Jeep JL Wrangler Steering Stabilizer Fox Performance Series 2.0 TS Installation
Decided to just keep my 35's for in town driving and just switch 37's when I do make it to BHO trails.
I still have to put my Rock Krawler No limits links on and my ASFIR skid on. I think for my part with the ASFIR skid and the RH LCA skids and both Rancho Differential skids I should be ok.
Eischman
Eischman
Kevin
Hortonville, WI
Consider the 2.1. You'll (very) likely stay on the middle setting 100% of the time.
That’s what I have heard, but for the same price you can get the Fox that has multiple settings instead of just 3???
Thoughts anyone that has these?
hoag4147
Rick
Colleyville, TX
2022 JLUR XR
IMO the benefits of the Fox ATS is it does give you more choices for your personal preference. We have folks on here running 10 clicks, 12, 15, 18, etc. it’s all about how it feels to you and the wheel/tire setup you are running. A big heavy 37 with beadlocks may like the much firmer feel and someone running a light 35 with light wheels may like much less. That’s the benefit to me, you can play with to hit the mark. ?? The one drawback discussed is placement and mounting position to ensure no contact with other parts. Good luck in your choices
engineXI
jank
so cal
rubicon
I'd been considering between the Fox ATS and the Icon Centerline . and just minutes away from pressing the buy button on the fox.
I like the fox ability to adjust (like my shocks). The Icon connected differently than the fox (to the track bar bolt) so that was actually a concern of mine, but after reading this thread, it looks like its an improved connection over the fox.
Punkn89
Alex
Maryland
2019 Wrangler
Resurrecting the thread - any long(er) term reviews on either the Falcon 2.2 or Fox ATS? I've had the fox 2.0 IFP, wasn't a fan - pulled too much.
rickinAZ
Rick
Phoenix
2026 MOAB 392
Don't spend the extra $100 for the 2.2. Five minutes after trying all three modes, you will settle in on the middle setting and never touch it again. Keep it simple and get the 2.1.
