Varilux
- Pete
- Dec 29, 2018
- Hickory Creek, TX
- 2018 Jeep Wrangler Rubicon
- Vehicle Showcase
- 1
About a year ago, I swapped my factory 33s for 37" tires, and installed a 2" Teraflex spacer lift at the same time. It worked well, but the Jeep jumped around a lot (definitely kept the driver "engaged") and slowly I developed a bit of a wobble right around 40mph when going over a one-side only bump. Not a death wobble, but a shimmy that was really annoying.
Anyway, installing Teraflex adjustable LCAs fixed the tracking issue, but the wobble persisted (actually got worse at first- which turned out to be due to the tire rotation we did when the LCAs were installed). Turned out the driver's front had thrown a weight- rebalancing the tire reduced, but did not eliminate the wobble. I (and a couple of fellows that know a lot more about Jeeps than I do) checked over the steering and suspension and couldn't find anything obvious, so they suggested the Teraflex Falcon Nexus ef 2.2 steering stabilizer.
I installed the stabilizer today (kept the Jeep on the ground and it took all of 35 minutes)- amazing difference! Set to "medium" there is no more wobble- at all- and the front just feels more solid. Set to "firm" the steering is more precise than some cars I've driven. I know stabilizers are usually considered a band-aid ("A properly set-up Jeep shouldn't even need a stabilizer" is the mantra my friends have drilled into my head), and we do plan to continue checking everything else. However, my Jeep now drives better on its 37" tires than it did on the original 33s. Completely, totally happy with the driving experience now- just hoping it lasts.
The Teraflex Falcon Nexus ef 2.2... as Martha Stewart would say "It's a good thing!"
