vkyolv
I was able to buy enough parts to build 3. I will keep you in the loop after I get mine built if you are still interested.Any body got a harness to sell? PM me.
Where were you able to get the parts from if you don't mind sharing?I was able to buy enough parts to build 3. I will keep you in the loop after I get mine built if you are still interested.
I googled the parts numbers in the how to guide. The only part that isn't correct is the sun sensor cap for those without the sun sensor.Where were you able to get the parts from if you don't mind sharing?
Also, I opted to splice the positive and ground needed for the in-cabin temp sensor to the 12v cigarette lighter plug. Pink/yellow (positive) and Black (ground).From my experience with this, I am not comfortable building another harness for some one else. If something goes wrong with my harness, that is on me to figure out. I don't want to be responsible if another harness that I built is messed up. Having said that, I have enough parts to build one more...although there are a couple of plugs that need to be salvaged (wires came loose from the pins and they are inside the plug). I will gladly sell the spare parts, wires and crimper if anyone is interested.
For the record, when I ordered my parts I got the following from:
Mouser Electronics - 829-13654871, 829-35088746, 829-13782037
Bristol Electronics - 13580635
PM'dFrom my experience with this, I am not comfortable building another harness for some one else. If something goes wrong with my harness, that is on me to figure out. I don't want to be responsible if another harness that I built is messed up. Having said that, I have enough parts to build one more...although there are a couple of plugs that need to be salvaged (wires came loose from the pins and they are inside the plug). I will gladly sell the spare parts, wires and crimper if anyone is interested.
Morning y'all.This is the first write-up I've done here on the forums so feel free to message me if you have any questions. Ever since Joe added the ability to turn on Automatic Climate Control for those who upgraded to the 7-inch UConnect, there's been many of us who wondered how we could add the missing sensors to make the "Auto" feature work as intended. I've had these sensors installed on my Jeep since April of last year, and it thought I would share on here a detailed guide on how to do it.
Be warned, there's a lot of information on the guide itself so make sure to read all of it thoroughly before attempting anything. Make sure to familiarize yourself with the wording used as to not get confused later on. Basic electrical and wiring knowledge is need to do this install.
The guide covers those of you who have an existing sun sensor on their Jeeps as well as us who have the base model and do not.
I bought my climate controls from Infotainment.Morning y'all.
I have a 2019 Wrangler unlim. sport. I updated to 7in radio which works great. Looking to upgrade climate control stack to have control knobs back for my wife. My question is this.
The wire harness from jeep only has 5 wires that plug into control stack but the control stack has 8 pins. If I switch out stack will the 5 wires be enough to make everything work?
It has sun sensor with auto lights, Infortainment has a kit they say will work. It includes the unit to reprogram climate controls apparently. Has anyone else dealt with them?
Thank you & always appreciate reading the chats.
Thanks. Did you install it yourself and were there only 5 wires from harness into control or did you have to add wires for 8 pin control?I bought my climate controls from Infotainment.
To be honest, I've slept since then. It was straight plug and play for me...other than having to make a harness for the in cabin sensor and sun sensor because I didn't have the wiring.Thanks. Did you install it yourself and were there only 5 wires from harness into control or did you have to add wires for 8 pin control?
I know what ya mean, can't remember what I had for dinner yesterday.To be honest, I've slept since then. It was straight plug and play for me...other than having to make a harness for the in cabin sensor and sun sensor because I didn't have the wiring.
