392 Weight Gain
guarnibl
Scottsdale / Sarasota
'09 JK, '26 Willys
Drove to the nearest CAT scale, 100 miles round trip....
The results are....with full tank of gas....without me inside:
Front: 3030 Lbs.
Rear: 2980 Lbs.
Full on: 6060 Lbs.
Sounds more reasonable than 7100 Lbs.
Sounds much more correct for sure. So 900 pounds of weight gain roughly.
bjm00se
JLUR 6sp ordered 11/3/21, picked up 8/30/22
Dayum. So that rockery is due for a visit from the Weights and Measures folks. They're overcharging by about 13% (assuming you weigh about 200lbs)
Shibadog
Bowling Green, Ky
2020 Wrangler Sport S hardtop
Not to hijack the thread, but what happened such that charges were brought following a motor vehicle accident?
If you don’t live in a “no fault” state then yeah, you can be charged. The ubiquitous “too fast for conditions” is applied a lot when a vehicle rear ends another…. By the by, that is one Seriously heavy Jeep?
dgerb
Don
Reno, Nevada
2021 JL 392
I though the same thing....however....they weigh before loading and then weigh after the loading....so it's the difference you're paying for.....
bjm00se
Sure, but the difference is probably off by 13% too, assuming the scale reads zero when empty.
dgerb
Don
Reno, Nevada
2021 JL 392
I still don’t think it matters as long as they weigh the dump truck empty before they load it and then again after they load it....it's the difference...?
stumblinhorse
Front: 3030 Lbs.
Rear: 2980 Lbs.
Full on: 6060 Lbs.
I think you need to apologize to your 392…. might have given it a complex. Nobody likes to be told they are too heavy. Admit you were wrong, bring a nice bouquet of shocks or something.
bjm00se
If the scale's just improperly "zeroed out" then I agree with you. But in that case, the empty scale would show 900, and you'd see that before you drove onto it.
But if it reads zero unloaded, then it's calibrated wrong and even the difference will be off proportionally.
Let's take a hypothetical scale at "Slick Sammy's" that reads off proportionally by 10%.
Suppose you throw a trailer that weighs EXACTLY 1000lbs on that scale. What does it read now?
An accurate scale would show 1000.
Slick Sammy's scale might read 1100.
Now throw EXACTLY 500lbs of rock in that trailer. Now what does it read?
An accurate scale would now show 1500.
Slick Sammy's scale will now read 1650.
Now, take the difference.
On the accurate scale: 1500 - 1000 = 500.
On Slick Sammy's scale: 1650 - 1100 = 550 - and you pay for 50lbs of rock you never received.
jeepken
Kenneth
Austin, TX
2021 JLUR 392
Front: 3030 Lbs.
Rear: 2980 Lbs.
Full on: 6060 Lbs.
This lines up with my weight and we have similar builds. I added the Teraflex Big Brake kit to help stop this beast and could not be happier with the results.
dgerb
Don
Reno, Nevada
2021 JL 392
Thanks for the feedback.....
1996cc
Oregon
22 JLUR 392
My local scale said 6,140-
5 - 37” Trail grapplers on real KMC Beadlocks (125lbs each)
Cavfab heavy ass tire carrier
LOD rock sliders
JCR full width rear bumper
Poison Spyder front bumper and 10S winch
MC 3.5“ lift, engine and muffler skid only (didn’t install the others)
Ultimate 44 front axle and trussed rear
King hydro bumps and reservoir shocks
Tuffy trunk
tool bag and supplies, full of fuel
Overwatch
Los Angeles
2016 JKUR, Sarge Green 392
I’m confused…I just wish that was new. My door sticker says 6100 pounds. Isn’t that what my 392 weighs? Why are some so much less?
Jeep Wrangler JL 392 Weight Gain tempImageJPqa2c
BeechAV8R
Roger
Southern CA / Northern AZ
Rubicon 392, CJ7 6.6L, Fusion Trophy Truck
GVWR is the weight limit determined by the manufacturer.
Curb weight would be what the vehicle weighs without passengers or cargo.
Not sure if curb weight includes full fuel load.
Mudduck
Jay
Michigan
2021 Willys 4door
if you don't want to pay for a cat scale/ or its too far. I have used weigh stations when they are closed. the scale itself is usually still on. Pull up the front axle and get the number, then pull all the way on and get the total number. Subtract the front weight from the total weight to get your axle weight for front and back. Just an idea.
MSparks909
Miles
NC
JLU Rubicon 3.0
I’ll be interested to see what mine scales after the axle swap/40s is complete. Definitely gonna get a number because I’m gonna be trailer shopping. Driving 2200+ miles one way to Moab next year on 40s with a 200-250 mile range doesn’t sound that fun ?
