Ronnie S
- Ronnie
- Mar 26, 2019
- Hamburg Township, Michigan
- 2019 Jeep Wrangler Rubicon Firecracker Red (2 Door) - 3.6L V6 24V VVT Engine Upg w/ESS - 6-Speed Manual Transmission
Problem is what if you have a manual transmission like me. Doubt there will be a relearn sequence for us. Mine does a herky jerk shudder at 42 mph in 3rd gear. Irritating.Just picked up my JL from the dealership. They said they were able to fix the shutter in the transmission.
Here's what I reported to them initially:
"CUSTOMER STATES AROUND 20-30 MPH UNDER LIGHT LOAD ON SLIGHT INCLINE, THERE IS A LIGHT SHUDDER FEELING. IT IS NOT A JOLT OR JERK, VERY LIGHT FEELING IN VEHICLE."
Here's what they wrote on my service report:
"NEEDS 8/9 SPEED TUTORIAL, AND PREFORM QUICK LEARN CHECK OUT CUSTOMER STATES THERE IS A LIGHT SHUDDER AROUND 20 TO 30 MPH, MOST OF WHAT IS EXPEIRINCED FEELS LIKE NORMAL SHIFT AND TORQUE CONVERTER OPERATION. PREFORM 8/9 SPEED TUTORIAL, CHECK FLUID CONDITION AND LEVEL. LEVEL IS GOOD AND CONDITION IS GOOD, CHECK FOR PCM TCM SOFTWARE UPDATES. NO UPDATES. PRERFORM SCAN REPORT AND ATTATCH, PREFORM TOPOLOGY REPORT AND AYATCH HAS NO FAULTS, RST ABOVE. 8 PREFORM TRANS QUICK LEARN LO 21580140. AND ADAPTIVE DRIVE LEARN POSECDURE, VEHICLE SHIFTS AND FUNCTIONS AS DESING TEST DRIVE OK. SERVICE ADVISOR ROAD TESTED, SYSTEM OPERATES AS DESIGNED."
Other than the poor grammar and spelling, looks like re-learning (re-tuning) the transmission did the trick. So far I can't feel the shutter. Time will tell, though (glass half empty kind of guy). Hopefully this information will help others who are having a similar issue.
Cheers!
