emdub
- Mike
- Dec 17, 2018
- Washington
- 2018 Wrangler JLU
- Vehicle Showcase
- 1
Same exact thing happens with my JLU which was built in Oct, 2018. Drives me NUTS!!!!!!!! I've had it to the dealership. They test drove it and couldn't duplicate the issue. I drove it with the tech in the passenger seat and could duplicate it on demand. They looked at the Jeep after the test drive and said their is nothing wrong.
A few posts ago, @Kevin Mojito described the issue perfectly:
"The symptoms are the same. Light throttle or steady state cruise, getting a bucking / surge / bogging / pumping brake feeling. It could also be described as a straight strong head wind pushing on the front of the Jeep. The easiest way to tell for me is, 1-2* incline ( used off road pages for that info ) try and stay around 25 mph steady. It can't do it. Feels like someone is pumping the gas, or brake pedal. I have tried manual mode, no change. It does the same at rpms from 1300-4000 rpm.Any gear,did not try any higher rpm. Once you know what your feeling, its at any speed ( mph ) or gear. The only thing that seems to be consistent is the rpm 1300-4000 rpm, with light or steady speed."
@JeepCares - Anything you can do to assist?
