3.6 Torque Curves
AnnDee4444
AnnDee4444
'18 JLR 2.0
Sara/AWE
Peak Sponsor (Level 2)
Horsham, PA
JT Gladiator
AnnDee4444
AnnDee4444
'18 JLR 2.0
Mustang AWD dyno as well... Good work!
Have you ever run the JL in 2WD and 4WD back to back? It would be interesting to know what the drivetrain loss is in 4WD.
Or what about 4-low even? In theory it should be the same, but I would like to see the ECU's torque reduction (I actually don't know if the 3.6 has torque reduction like the 2.0... just assuming).
BlackGenesis
Andrey
Muskegon Michigan.
18 Sahara unlimited
1:1 gear ratio yeild highest power reading. Lower gears or 4 low would show less.
AnnDee4444
AnnDee4444
'18 JLR 2.0
...That's literally the whole point. I want to know how much more the drivetrain losses are in 4-High, and how much the ECU limits torque in 4-Low.
Sara/AWE
Horsham, PA
JT Gladiator
We haven't, and I wouldn't have the staff available to do that as we are all hands on deck getting systems build and out the door. The dyno sits idle, pining to put the next system to the test... haha.
Kojak86
Tom
Poland
Chrysler Town & Country 2013, 3.6 V6
Hi there! My name is Tomasz Dembkowski. I am from Poland but I use Chrysler Town & Country 3.6 V6 pentastar (2013). I did a lot in a car, for example, changing filters, oils, fluid, sparks, seals, PUG upgrade. I have also K&N air filter in the original place.
Besides everything, after dyno test I am not happy. Score is very low, only 232KM (287KM +/- 10% should be) and the chart is not smooth. I have significant drop around 5000rpm. I do not have "check engine" or any other problems concerning OBD.
What is wrong with a car, any suggestions?
Thank You for Your help.
Jeep Wrangler JL 3.6 Torque Curves Resized_20220225_143303
AnnDee4444
AnnDee4444
'18 JLR 2.0
A 3.6 from 2013 is somewhat different from the 2018+ 3.6, which is what is being discussed here.
You might have better luck in one of these forums:
https://www.ramforumz.com/forums/3-6l-220-cu-in-pentastar-v6-specific-topics.253/
https://www.chryslerminivan.net/
AcesandEights
Aces
So. Oregon
2024 Toyota 4Runner
It funny when someone says the 3.6L makes all of its power high in the RPM range, no power off the line, when clearly it makes most of its power off the line and runs flat.
Kojak86
Tom
Poland
But I think that I have some problem which I am trying to find out.
4a4c55
near Seattle
2010 BMW M3, 2020 Sahara JLU
Er, I can't sort out these graphs. The title is "stock torque curve", but every line in the legend mentions some aftermarket company. What do the curves actually mean?
AnnDee4444
AnnDee4444
'18 JLR 2.0
They are the stock "untuned" curves published by the aftermarket companies.
For example, just the red line from the Superchips plot.
Jeep Wrangler JL 3.6 Torque Curves 2020dynojtcorrectwheel
Aren't those torque curves? HP curves of the 3.6 still show a nearly straight slope from idle to redline.
AcesandEights
Aces
So. Oregon
2024 Toyota 4Runner
Aren't those torque curves...
The thread (title) is about torque curves, but yeah.
(not that you're saying this) When I've been replying to others, it's typically because people are saying the 3.6L makes all of its power (torque) higher in the RPM range and that's why it sucks, why it's a minivan engine and worthless off road (typically compared to the venerable 4.0L). Well, the fact is, it makes a bunch of its torque off idle, and works really well in the JL, and as an off road engine. The JL 3.6L, manual transmission, and 4.88 gearing (with front and rear lockers) is the epitome of an off road capable vehicle.
