"Stock" OEM+ 2018 JLR 2.0
AnnDee4444
'18 JLR 2.0
Documenting my Ocean Blue 2018 JL Rubicon. I like things to appear stock but function well, and realize that sometimes aftermarket parts are not an upgrade.
OEM & Mopar parts listed first, then aftermarket in alphabetical order.
BrandPartPart #Notes & Thread Link
OEMJLUR front springsRemoved for more height & spring rate
OEMXtreme Recon Springs68605689 front 68622389 rearGained about 1.5" in the rear, needed 1.5" spacer in the front to level with winch
OEM392 Fox Shocks68481296 front
68481297 rear
Bronze sticker, required +1" bump stops
OEMXtreme Recon Sway Bar End Links68480860 front
68480859 rear
Not necessary, but "correct" lengths for the +1" bump stop. Plus they're stainless steel
OEM19mm rear sway bar68247954Sway reduction at high speeds in crosswind, no loss of flex
OEMSteel replacement steering boxWarranty: still needs occasional adjustment, not sure if better than aluminum box
OEMPassenger side "Trail Rated" badge68309634ACAntenna delete
OEMPassive Entry Door HandlesPSVENTRY18DPTUsed Jscan to enable
OEMGladiator Grill Inserts6QN21RXFAC
6QN22RXFAC
6QN23RXFAC
Better cooling?
OEMClass 2 Tow Hitch82215209Used take-off parts
MoparTrailer Tow Wiring Harness82216359See post # 20 for install notes
MoparAuxiliary Switch Bank82215798To be installed, planning on
Aux 1: future compressor
Aux 2: winch on/off
Aux 3: winch out
Aux 4: winch in
MoparFairlead Adapter Plate Centered82215528ABNeeded to be bent to bumper's curve, finish is a perfect match
MoparDoor Sill Guards82215393Could be better, but better than nothing
MoparCargo Net82215413Not very useful with no back seat
Mopar PerformanceLower Control Arms68322798AAAround 6 degrees of caster at stock-ish heights
Jeep Performance PartsRock Rails82215129ABWider than OEM Rubicon, can be used as a step. Also blocks road debris.
American Adventure LabFire Extinguisher MountJL-1695-3They actually made it, so I had to buy it.
Artec IndustriesRear Axle LCA Bolt-on SkidsJL4599Minimal added bulk, more of a reinforcement
AsfirEngine skid plate547459Removed: bent, poor oil drain plug hole location
Baja CustomsAluminum heater hose & coolant tank fittingsNot installed yet
Banks PowerRam-Air Intake97700Removed: not happy with fitment, negligible performance gains, odd throttle behavior. Discontinued?
BF Goodrich315/70R17 KO208884"35s"
CenterlineWastegate RodTL449Fixed turbo rattle
DynatracBall JointsDT BJK-JL
Factor55Hawse Fairlead 1.0"00016Matches the Rubicon gunmetal color
Factor55Loop Guard00450-06I'm not a fan of the winch hooks
Fishbone OffroadTub Rail Tie DownsFB25241Instructions want you to drill into the body because they didn't put an extra hole for 2-door compatibility. Should be longer.
FumotoOil Drain ValveF106NEasier oil changes with skid plates
Interstate BatteryGroup H7 AGMMTX-94R/H7Costco
Innovativeat ProductsWinch CoverIJKP-13Spray painted matte black
JscanLinkUsed for:
Passive Entry Doors​
Speedometer Correction​
Enabling fog lights with high beams​
Maximus-3Winch Mount PlateJL1012WM12,000 pound rating for OEM steel bumper
Maximus-3Winch Filler Trim PlatesJL1017FZI don't route the conduit through the provided hole, I find it rubs on the grill. Update: still not using the hole with the relocated control pack.
Maximus-3Front Tow LoopsJL1026TLHD version sold now
Maximus-3Closed Rear Tow LoopsJL1028RTWinch points & bumper protection
Maximus-3Front Differential Drain Plug SkidJL5022DSMinimalist protection
MetalcloakFront Track Bar Reinforcement Bracket7688*Removed: wasn't able to sufficiently tighten track bar
MetalcloakFront Sector Shaft Brace7690Never installed. Was sold as fitting stock height, which it doesn't
MetalcloakDuroSpring Bump Stops7218Adds 1" of bump stop necessary for the 392 shocks
MetalcloakRear Bumper ReinforcementR75048See this thread
MishimotoIntercooler PipeMMICP-JLH-18WBKUsed OEM couplers & hose clamps. Throttle feels a little more immediate and accurate
Mountain Off RoadOil Pan / Transmission Skid PlateKJLOPSP2.0T.BLKNever installed: didn't fit with 2018 2-door gas tank
Mountain Off RoadFire Extinguisher BracketKJLFIREB2DDS.BLK
KJLFIREB2DPS.BLK
Removed: elastic wears out and they never held securely
Next VentureEngine/Trans skidProduct has been updated to 7000 series since purchase
Next VentureRear Diff Skid & Pinion GuardNV-JLT-RDS220
NV-JLT-M220-Spacer
Needed slight clearancing near the eTorque battery skid
Redline TuningHood Struts21-20003-02Works like a stock part
Teraflex1" Front Spacer +
0.5" Front Spacer
1155100
1155110
Compensates for winch weight with the Xtreme Recon springs
Terra AcousticsSoundstage Speaker Upgrade KitCompany is now Audio Uprising
Under Cover FabInner Tire Carrier Reinforcement BracketUCF652Replaced & painted some hardware for more OEM appearance
WarnZeon 10S Winch89611
Warn78" Control Pack Relocation Kit89960See posts below
WarnMolle Storage Bag102648Fits good on the Rubicon seat backs
Z AutomotiveSGW Extension CableZ_SGW_EXTMakes plugging in the programming cable much easier
A few accessories that I don't think go in the list above:
AnnDee4444
AnnDee4444
'18 JLR 2.0
For a few years I've been thinking about relocating the winch solenoid to under the hood. Today I purchased the missing piece that I wanted to source before starting this project: A cover for the hole left in the top of the winch after moving the solenoid box from Innovative Products.
Some photos from https://www.jeepgladiatorforum.com/...er-control-pack-relocation.46150/#post-745241
Jeep Wrangler JL "Stock" OEM+ 2018 JLR 2.0 PXL_20220206_012144824.MP
And inspiration for future from https://www.jeepgladiatorforum.com/...s-control-pack-relocation.42575/#post-1270681
Jeep Wrangler JL "Stock" OEM+ 2018 JLR 2.0 363972-45dab4b027fe28e6dc30169c64e3c315
Jeep Wrangler JL "Stock" OEM+ 2018 JLR 2.0 363974-ecc2889c642048368539af26fc81d344
Edit: looking at using something like this: https://813fabrication.com/products/jeep-jl-gladiator-underhood-electrical-accessory-plate-large or the smaller version: https://813fabrication.com/products...y-plate?contact_posted=true#ask-question-form
Not a JL, but good install video:
Remorseless
NC
Holier Than Thou Internet Bully, Part-Time Online Boy Scout, Full-Time Arson Enthusiast, Napalm Compatible, Not Only The Guy Who Defines What A Jeep Guy Is, But Also The Guy Who Defines What A Jeep Thing Is, Guy Who Has The Authority To Do That
That Factor 55 loop guard is pretty neat. What's your experience been like using the winch line with just the eyelet? Did you pull the metal guard on it or leave it in place?
AnnDee4444
AnnDee4444
'18 JLR 2.0
I leave it in place, and it hasn't deformed. I've really only had to winch a few times, so maybe it's not enough for the more hardcore Jeepers. Might be worth noting that I use soft shackles everywhere except for the D-rings directly on the Maximus-3 tow loops (you can see in the snow photos above).
Remorseless
NC
Yeah I'd only ever use it with soft shackles. But good to know it hasn't failed or gotten torn up over the years. I've been thinking about how to set up a 12k lb winch for the truck to be metal free (or near as can be) and it's a few hundred bucks on top of the winch for a bespoke metal free winch line. But being able to use the stock line is something I hadn't considered for whatever reason. Neato.
AnnDee4444
AnnDee4444
'18 JLR 2.0
Some photos
Jeep Wrangler JL "Stock" OEM+ 2018 JLR 2.0 PXL_20260813_163456265
Jeep Wrangler JL "Stock" OEM+ 2018 JLR 2.0 PXL_20260813_163329436
Jeep Wrangler JL "Stock" OEM+ 2018 JLR 2.0 PXL_20260813_163943254
Remorseless
NC
AnnDee4444
AnnDee4444
'18 JLR 2.0
Still have some wiring changes I want to do, but the solenoid relocation is now functional. I ended up spraying the Innovative Products winch cover with some matte black paint to try and hide their laser-etched logo better. The Warn wire cover box is a little loose, probably needs a piece of rubber underneath. Also need to cover the wires with something UV-proof.
Jeep Wrangler JL "Stock" OEM+ 2018 JLR 2.0 PXL_20260827_182825229
Jeep Wrangler JL "Stock" OEM+ 2018 JLR 2.0 PXL_20260827_182845587.MP
AnnDee4444
AnnDee4444
'18 JLR 2.0
AnnDee4444
AnnDee4444
'18 JLR 2.0
Still adjusting things, but this is the general idea of where I think want things located. Bracket is temporary, has some extra holes from where I didn't plan well. I'll need to shorten some wires, get a positive battery cable, and I'll route that tiny ground somewhere else (there's an existing ground lug under the solenoid).
I'd like to control the winch from the aux buttons (that I don't have yet). My plan is to cut up a remote socket (Warn 98348). This would also allow quickly changing to a standard remote for those times I want to operate the winch from the front of the vehicle.
Jeep Wrangler JL "Stock" OEM+ 2018 JLR 2.0 PXL_20260828_160037442
Jeep Wrangler JL "Stock" OEM+ 2018 JLR 2.0 PXL_20260828_160132874
Jeep Wrangler JL "Stock" OEM+ 2018 JLR 2.0 PXL_20260828_160158277
Cips
Anthony
Bucks County PA
2021 Wrangler Unlimited Willys
Sales
I admire your build. Nothing over the top, but subtle improvements that fill what you're missing.
AnnDee4444
AnnDee4444
'18 JLR 2.0
Worked on the winch wiring some today. I was having trouble re-fitting the airbox and getting the wires routed the way that I was happy with. Ended up removing a headlight which made things much easier. Also the grill does come off with the winch installed, but I do have the two middle clips removed from the uncut grill.
Wiring under the power steering bracket, above fender liner:
Jeep Wrangler JL "Stock" OEM+ 2018 JLR 2.0 PXL_20260831_215733200
Routed towards the rear, just on top of the fender liner and under all other wiring/brackets, then under the battery box. Side note: what does this vent cool? It's fed from the grill opening, but doesn't go into the airbox and isn't pointed at equipment. Could it be to get fresh air to the power steering pump or just airflow in the engine bay?
Jeep Wrangler JL "Stock" OEM+ 2018 JLR 2.0 PXL_20260831_221733596
There's a nice gap to bring all the wires up, roughly center of the battery. I think mine might have excess wiring here due to eTorque.
Jeep Wrangler JL "Stock" OEM+ 2018 JLR 2.0 PXL_20260831_221921940
It's pretty easy to tuck these wires back in, and I don't mind being able to remove the solenoid from the engine bay without actually disconnecting it, so these will stay the unmodified 78" length :like:. I still don't have a positive cable, and I'm running original #2 ground to the winch even thought the kit doesn't say it's necessary. Note the factory airbox installed like stock, with no wires anywhere in the airpath.
Jeep Wrangler JL "Stock" OEM+ 2018 JLR 2.0 PXL_20260831_223310693
I think something like this might be a better location for the solenoid, as it allows a little clearance around everything (rag is for mock-up purposes). This location will likely interfere with other aftermarket accessory mounting brackets like the ones from 813 Fabrication, but I think it will work for me. Also noticed a threaded hole next to the leftmost painted fender bolt in the photo. I might use this for a shorter bracket.
Jeep Wrangler JL "Stock" OEM+ 2018 JLR 2.0 PXL_20260831_223748674
Edit: small update, didn't want to bump. Added some sleeving to the exposed wires.
Jeep Wrangler JL "Stock" OEM+ 2018 JLR 2.0 PXL_20260901_202430945
Roky
Roky
Jeep Wrangler JL "Stock" OEM+ 2018 JLR 2.0 {filename}
That’s where mine is, and got it wired to aux switch….. did this because my winch has on/off switch on the winch itself, to easy for shenanigans ……took a minute to remember to turn on switch “before “ I got out though 🤣
Bad66GT
Christopher
Humble, Texas
2027 Rubicon X(waiting for it), 2025 Ram RHO, 1966 Mustang GT
Looks great and a great list to share with everyone. Thank you!!
I already ordered the lower control arms for a Jeep that isnt in my driveway lol
