Winch Install issue
bacon392
Northern NJ
Sarge Rubicon 392 XR
I completed my Zeon 10S install today with the Warn winch plate. Im running into a clearance issue with the factory steel bumper as the bottom of the opening is higher than the lowest part of my Warn hawse fair lead. The metal from the bumper opening will absolutely abrade the synthetic line. I was able to get the fair lead in the right position, but the torque from the winch reeling at the end pops it down.
I was planning to take my angle grinder to the bumper opening to enlarge it, but figured I’d ask here first.
Thanks!
nsfw_andy
2022 Hydro Blue JLUR Ecodiesel
Post some photos, but I'd just cut it anyways, it doesn't really hurt anything.
JPAloha
Saskatoon
2019 JL Rubicon 2 door, 2022 JL Rubicon 4xE, 2018 JL Rubicon 2 door
Accredited Financial Planner
I didn’t have that issue with mine. Pics would help.
Jeepeto
Josh
North Texas
2021 JLUR XR
Sparky
Thanks!
What bolts are you using to attach the fairlead? It almost sounds like they are too small to self center on the hole?
supermike
mike
Irvine CA
18 JLUR 6 speed 2021 JLUR 392
picture?
I had the warn winch plate, Zeon 10S and oem steel bumper. no issue.
bacon392
bacon392
Northern NJ
I am thinking you're right. I got the winch and fairlead used and used some 3/8" hex button head grade 8 bolts I had. They fit well enough in the fairlead, but the holes in the bumper are larger. I'll try 7/16" bolts
bacon392
bacon392
Northern NJ
bacon392
bacon392
Northern NJ
Jeep Wrangler JL Winch Install issue 7C7AD442-CE00-4E0C-B216-B6A3D72A9CEF
It’s not a great photo, but I increased the contrast so you can make out the lip of black metal sticking up past the hawse fairlead about 1/8” of an inch.
I think larger bolts may force the fairlead up enough.
bacon392
bacon392
Northern NJ
See the acorn nuts used. There is about 1/8” of vertical clearance from top lip of fairlead to winchplate as I feel with my finger.
Interesting. The bolt comes through from the inside and the nut is on the outside? I have it mounted the opposite way with a hex head button bolt facing inward from the outside.
