Which winch hook/shackle do you guys recommend.
Pareto Offroad
Brandon
Durango, CO
2020 JLUR
Makin’ sawdust
None, actually. Buy a $7 fid and add your own loop to the line. Then just leave a soft shackle in it to keep the line from rolling up into your spool.
Nearly free, almost no added weight, more versatile than a hook, and safer during recovery as there's very little weight on your line.
https://www.amazon.com/SGT-KNOTS-Plastic-Splicing-Fids/dp/B082YC9K3H/
Pareto Offroad
Brandon
Durango, CO
2020 JLUR
Makin’ sawdust
I went the ultra lightweight and less connection point route.
Perfect. There's no marketing machine behind this method, but it's the best I've found.
Pareto Offroad
Brandon
Durango, CO
2020 JLUR
Makin’ sawdust
Brennan is a really good dude. He's the one that introduced me to the idea of using a soft shackle in a bremmel loop.
Everything he sells is well thought out and non-bullshit. You won't find anything annonizied red or neon blue. Just well made stuff and good prices.
There's a decent chance I'll be moving our Pareto offroad to Durango where he's located and I'm excited to be in the same area.
Either way, I will likely be offering his recovery gear on our site at some point.
Terrymo
Terry
2023 JLURXR 3.6 ET
I want to try one of his Tauler Jack kits but I have zero welding skills that I would trust. I wish he sold some finished jacks but maybe it’s not worth it for liability or shipping cost reasons?
https://brennans-garage.com/products/tauler-jack-kit
Pareto Offroad
Brandon
Durango, CO
2020 JLUR
Makin’ sawdust
For sure. Way better than a high lift, at-least for my needs.
There's gotta be a fab guy in your area that would weld it up for you. It's always good to know a guy that can create art with a welder!
This is the guy I use in Denver: https://www.google.com/search?q=Fir...YWIJThkAeI2OF3LuloVRwRnd76Hs5JQ:1716994382245
That'll give you an idea of what to look for.
Terrymo
Terry
2023 JLURXR 3.6 ET
This is the guy I use in Denver: https://www.google.com/search?q=First Choice Fabrication&ludocid=5529540698764335521&ibp=gwp;0,7&sa=X&ved=2ahUKEwiViPDBjrOGAxW-FVkFHaupAs8Q_coHegQIIhAB&sxsrf=ADLYWIJThkAeI2OF3LuloVRwRnd76Hs5JQ:1716994382245
Yeah I’ve used a shop in the past that has an engineer and certified welders on site that fabricate and weld heavy duty trailers. So maybe I’m just procrastinating. I carry a Hi-lift in addition to a HMMWV H1 jack, but I would be happy to ditch the hi-lift. The Tauler seems less likely to cause unforeseen dental work.
vaJLUR
NC
2020 Jeep JLU Rubicon
I have a splice in flatlink that I like and have used a fair bit pulling others.
For the rear I have a F55 insert that you can run a d-ring or soft shackle through (I use soft shackles) but reaaaallllly like what @Terrymo posted from Brennan
Terrymo
Terry
2023 JLURXR 3.6 ET
I have good recovery points that are chamfered for soft shackles on my ARB bumpers. I carry the soft shackle receiver adapter from Brennan in the event I can help another vehicle (like most pick ups) with a receiver hitch.
Odyssey USA
Daniel
www.youtube.com
2021 JLU Rubicon
I removed the metal from the end of my winch line. A soft shackle goes right in. I sold my flat E link.
Old Jeeper
Don
US Army Infantry, IT Engineer
I'm a fan of the winch thimble fan myself, but I run a knock off $20 amazon special.
Here is a pic of the original Winch Thimble. A friend of who invented it has a testing company and does testing for automakers. I was sent this around 2006, asking me what I thought and to test it. It's
Jeep Wrangler JL Which winch hook/shackle do you guys recommend. IMG_6539.JPG
a great thimble, note how the top is wound around the front of it.
