What engine Would You Chose? (Poll)
If Jeep could only make 3 engine options in a wrangler what 3 would you want? Can have 6MT or 8AT
  • 3.6 Pentstar
  • 3.6 Pentstar E Torque
  • 4.0 I6
  • 2.0 I4
  • Eco Diesel
  • 6.4 Hemi
  • 5.7 Hemi
  • 5.7 Hemi E torque
  • 2.0 With 4xe
  • 3.0 I6 Huricane High Output
  • 3.0 I6 Hurricane Standard Output
  • Cummins?
  • Hellcat V8
  • Magneto Concept
  • Pentstar 3.6 with ESS (Why would you choose this?)
Results are only viewable after voting.
AnnDee4444
'18 JLR 2.0
?? (80:1 crawl ratio)
Ohh. I interpreted it as compression ratio... since it was adjacent to displacement & crankshaft size.
swampflyer
rick
florida
retired
I-6 without turbos? They're a fundamental part of the design such that the turbo-specific exhaust manifold is integrated with the cylinder head. Good luck on them neutering it like that.
I know just saying. Had experience with turbos a lot of heat to consider. And wait until you have to replace one. $$$
NWJeepr
Twin Peaks
2025 Wrangler 2-door
2.0 Hurricane
3.0 Hurricane (standard output)
Cummins?
2.0 because it’s a great motor, fun to drive, and gets great fuel mileage.
3.0 for a little extra scoot and trailer towing with a gas motor
And a small Cummins (turbo I4) because that probably should have gone in instead of the VM 3.0 ecodiesel.
Dusty Dude
Colorado Springs, CO
1970 Ply Roadrunner, 2010 Challenger SRT
Anything with a turbo or hybrid should be thrown in the trash. Period. Overly complicated and unnecessary. The only reason they came into being is because of government intervention.
I chose the Pentastar because there is not a modern I6 without a turbo. A V8 for a higher output option. I would use a smaller Cummins like a I4, again without a turbo.
Simple, reliable, and easy to maintain.
Flip
Johnny
Virginia
2023 Jeep Wrangler Sport
Retired Power Plant Engineer
I think a 5.7 hemi would be tempting but I'm reasonably certain it would be a gas hog and I'm not sure how that would work in a 2-door jeep. Wheelies? ?
J.Ferreira
Castle Rock, Colorado
www.tmgps.org
1999 Jeep XJ
I only have one option as I only drive manuals. Answered as such.
BUT if the manual had been offered with the diesel, I would have went for the diesel.
J.Ferreira
www.tmgps.org
1999 Jeep XJ
The 392s have full time 4WD...So I'd imagine like that. :CWL:
2nd 392
Ca
Just a little underpowered, a 392 about perfect, especially fun with a Tremec Magnum 6 spd. A Wrangler is wider, longer and heavier than a CJ no problem in the 500+- hp range, Hellcat, not sure, but a lighter, smaller ~700 hp 63 torqued the right wheels off the ground with sufficient traction. Way off the ground ? ? :please: The ~400 hp range was perfect, and I ruined it. ?
LKG
Larry
Boise, ID
23 JLUR (soon), Gen 2 Cummins, 22 Sport Alt. R.I.P
2.0 Hurricane
Cummins?
A 2.8l Cummins would be freaking unbelievable crawling, not to mention MPG's.
AFD
Northeastern US
2023 JL Rubicon (2DR/V6)
It's fine and Jeep are pussies for not giving us the 2-door with a V8..
