Tire Cupping/ Causes?
kah.mun.rah
Merenkahre Jr.
Duat
IMO it's the nature of the beast with mud terrains. Sometimes the tread blocks vary in stiffness and the soft ones wear quicker than others around them. MT look cool and I tried MT once but now will only use AT.
azwjowner
Phoenix
I have the full MetalCloak 2.5" GameChanger Suspension. I thought they replaced the stock ball joints with their Duroflex™ Joints
I rotate every 7500, but have always used that interval. i have to wonder if it is these tires. They also suffer from "radial draw".
I've heard for mud tires you need to rotate every 3000 to prevent cupping. For all terrains I do 5000.
bigfoot21075
bigfoot21075
Robert
Maryland
2021 JLUR, 2012 Ford F350
Not ball joints, they are fine. I will get a set of A/T Nittos or Falkens and move on...
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
You're gonna roll the dice and assume the problem is in your tires and not your suspension? If you do then make sure you look for cupping in a few thousand miles. No need to fully trash another set if it's really something wrong elsewhere.
bigfoot21075
bigfoot21075
Robert
Maryland
It is hardly "rolling the dice" :LOL: The Metal Cloak Game Changer is a first rate suspension. The components are in excellent condition. Control arms, bushings, steering are all as tight as can be. There are no noises of any kind coming from it.
Ratbert
PNW
Software Engineer
Hopefully you'll pay slightly more attention to potential cupping next iteration. You don't look at / glance at your tires every time you air up / down?
bigfoot21075
bigfoot21075
Robert
Maryland
Have an appointment June 14 to get 4 new BFG All-Terrain T/A KO2 's. Looks like they will be $435 a piece plus $29.00 mount and balance
Ratbert
PNW
Software Engineer
It sucks that the 37" version of their KO3s won't be out until something like 2026.
bigfoot21075
bigfoot21075
Robert
Maryland
You have to rotate often to keep agressive tires in check. I learned the hard way.
Funny,
I have 37/13.5 R18 Toyo Open Country A/T's on my quad cab F350, they have 40k on them and I have never rotated them and they are fine, still quiet and not cupped.
AZ Hella
Sonoran Desert
JLUR
Funny,
A/T tires are alot more forgiving than an M/T.
bigfoot21075
bigfoot21075
Robert
Maryland
just to be safe, i will rotate
To be safe I will rotate my new A/T's every oil change., really that is about every 8 or 9 months.
Ratbert
PNW
Software Engineer
Rotate all five. It's foolhardy to just do four and miss out on ~20% of your treadwear.
bigfoot21075
bigfoot21075
Robert
Maryland
I am not replacing the unused spare and will not be able to rotate it in. i am OK with that.
alphawolff
california
2021 JLU
For what it's worth cupped tires is almost always a shock issue. The shock's job is to not only absorb the initial impact, but to also help the tire rebound back onto the road surface.
A worn shock may absorb the impact fine enough but not have enough stiffness to properly rebound it. If you're running 28 psi there's a very real chance you haven't noticed the worn shocks due to the tires themselves absorbing a significant amount of road impacts.
Replace your shocks. They last maybe 40k-60k miles at most, especially with larger tires. Just because they aren't leaking doesn't mean they aren't worn. If you've ever noticed the factory XR packages come with some seriously beefy shocks, and those are 35s.
