Tire Cupping/ Causes?
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
For my education, "cupping" means the center is worn out before the edges? If yes, wouldn't that happen because of over inflation?
It's more like this:
Jeep Wrangler JL Tire Cupping/ Causes? 1717162532934-k0
bigfoot21075
bigfoot21075
Robert
Maryland
2021 JLUR, 2012 Ford F350
Not really, it is where blocks of tread are depressed next to ones that are not, this forms cups in the tread blocks. These are pretty severe. the above picture is the perfect illustration.
roaniecowpony
Retired Engineer
I have the full MetalCloak 2.5" GameChanger Suspension. I thought they replaced the stock ball joints with their Duroflex™ Joints
I rotate every 7500, but have always used that interval. i have to wonder if it is these tires. They also suffer from "radial draw".
The Duroflex joints are in the control arms, not the balljoints. Two different functions.
bigfoot21075
bigfoot21075
Robert
Maryland
THANKS!! My steering does not wonder, I don't have a clunking noise, there is no squeaking or other. Nothing on the floor boards or any other usual signs that i know of. It seems hard to believe that 27k miles of 99% highway use has cause such an early failure on such a commonly used configuration..... Doesn't it?
roaniecowpony
Retired Engineer
I would also suspect your balljoints (steering) are worn.
roaniecowpony
Retired Engineer
Factory balljoints are notorious for getting loose with very low mileage. They are expensive for good balljoints and expensive for the labor to install.
bigfoot21075
bigfoot21075
Robert
Maryland
I will put it up in the
I will put it in the air and have a look. Clearly better than killing another set of tires! THANKS for the tip you all.
tomk62
Tom
South Carolina
2024 JLU Sahara Anvil, 2019 Cherokee
I see ... so rotationally (versus across the width of the tread) there is a band with a pattern of high and low spots "cups" along the outer edge?
I would think that there would have to be something mechanical in the suspension that would cause this cyclical/oscillating pattern wear at a regular frequency (not sure how that could even be possible given variable speeds), or more likely a defect in the tire itself?
clayps
London, Ontario Canada
2010 Jeep Wrangler Sport
We recently rented a Willys 4xe with about 30k on the clock. The stock Firestone MTs were so badly cupped that we couldn’t wait to get out of it when we got to our destination. Howled in town and on the interstate. Vibrated the seats etc. Being a rental it’s very likely the tires were never rotated. We turned it in for a different rental (same model Jeep) and the tires were night and day different with only 14k. MTs really should be rotated very regularly.
rivercrossing
Ben
Bronco
Are all 4 tires cupped or just the front?
I have seen cupping on trucks with IFS, so it is not a solid axle only thing.
tomk62
Tom
South Carolina
Tire cupping, also known as scalloped tires, is a type of uneven treadwear that appears as if someone took an ice cream scoop and scooped out part of the tread every three to four inches around the circumference of the tire. Here are the main causes of tire cupping:
  1. Misaligned Tires: When tires are misaligned, their contact with the road may be uneven, causing uneven stresses on the tread. This can result in a “sawtooth” wear pattern at the edges of the tread, known as “heel-toe wear” in engineering terms.
  2. Worn Suspension and Shocks: Components like shock absorbers, struts, and bushings wear out over time. When these suspension parts are in bad shape, they can’t effectively dampen the impact between the tire and the road. As a result, the tire bounces slightly, creating uneven points of pressure and leading to tire cupping.
  3. Unbalanced Tires: If the weight across the circumference of a tire is not evenly distributed, it can cause unbalanced tires. Severe imbalance can result in some sections of the tread meeting the road with greater force than others, leading to increased wear in those areas.
  4. Cheap Tires: Not all tires are equal in quality. Some lower-quality tires may be more susceptible to cupping, especially on a vehicle with a worn suspension or less-than-perfect wheel balance.
The problem with tire cupping is that it disrupts the continuous contact between the tread and the road surface. This inconsistency reduces traction, especially in emergency situations, increasing the risk of loss of vehicle control. To prevent tire cupping, ensure proper tire maintenance, address suspension issues promptly, and have tires balanced by a certified mechanic. Remember that maintaining well-balanced tires can extend their lifespan by up to 20%.
bigfoot21075
bigfoot21075
Robert
Maryland
SUPER informative post! Alex, i will take what is 1, 3, and 4 for all of the money.
