Tire Cupping/ Causes?
bigfoot21075
Robert
Maryland
2021 JLUR, 2012 Ford F350
Hello!
I went to get my Mastercraft Courser MXT 37x12.5x18 (Mud Terrain) tires balanced on my 2021 JLU with a Metal Cloak lift. The tech pointed out that the tires are badly cupped! The tires and suspension have 24,000 miles on them. The entire Jeep has 27,000. The place that originally installed the tires said to keep them at 28 psi unless going off road, and I have done that. These tires are so bad now (the noise, some vibration) that they need to be replaced. I am hesitant until I know why these tires cupped so bad so fast.
I would GREATLY appreciate you help. The shocks are not leaking and the suspension is still in great shape, but I will say the Metal Cloak 2.5" lift suspension s pretty soft over all from day one. Not sure if that makes a difference. I am going to go with a different tires, but want to make sure this will not just eat those up as fast.
THANKS!!!
DaltonGang
Doesn't Play Well With Others
Hello!
THANKS!!!
Cut and pasted possible reasons:
  • Suspension issues or misaligned wheels
  • Unbalanced tires or damaged wheels
  • Low-quality and cheap tires
  • Worn or damaged suspension components
  • Poor alignment
bigfoot21075
bigfoot21075
Robert
Maryland
Happen to be running higher backspace/lower offset wheels? If so, my money is on balljoints.
No nothing like that, the backspace is not that different than stock..... Ball joints are tight and the suspension is silent. It is a pretty standard configuration for any JLU with 37's and a 2.5" lift. i avoided anything to extreme as I was worried about bearings.
beaups
Sean
Ohio
2020 JL
Not “that” different + 37’s could be enough. The stock ball joints are shit and they fail in a way that traditional tests don’t diagnose. I chased random DW and cupped tires for some time before taking a leap and replacing the ball joints. In my case on 33’s with only slightly reduced wheel offset and <40k miles. Just food for thought.
jadmt
jeff
montana
several years ago I looked at getting a set of mastercraft Courser mxt's and the tire shop that sold them told me that they were notorious for cupping.
#4Jeep 1st Wrangler
mark
north olmsted ohio
Haven't heard how many rotations were performed? Should rotate every 6k... Also usually X pattern.
jadmt
jeff
montana
I personally could never wait 6000 miles. I have always done the a 5 tire rotation every 3-4000 miles. that schedule has served me well on my last 5 jeeps.
bigfoot21075
bigfoot21075
Robert
Maryland
I have the full MetalCloak 2.5" GameChanger Suspension. I thought they replaced the stock ball joints with their Duroflex™ Joints
I rotate every 7500, but have always used that interval. i have to wonder if it is these tires. They also suffer from "radial draw".
yokramer
Snark Incarnate
It quite possibly could just be the tires. MTs from a budget brand its not like thats out of the question.
bigfoot21075
bigfoot21075
Robert
Maryland
I am leaning toward a se t of Nitto Recon Grappler A/T - they are $480.00 each for 37x12.5.18.
yokramer
Snark Incarnate
I mean no reason to change the tires before they are done, a bit of cupping isnt the end of the world, just gonna be a little noisy. Did they do an alignment as well?
Remorseless
NC
Holier Than Thou Internet Bully, Part-Time Online Boy Scout, Full-Time Arson Enthusiast, Napalm Compatible, Not Only The Guy Who Defines What A Jeep Guy Is, But Also The Guy Who Defines What A Jeep Thing Is, Guy Who Has The Authority To Do That, Dictator of What Is or Is Not 'Hard Wheeling', Arbiter of What Counts as an Obstacle, Weak Ass Bitch Identification Agent, Definitive BBQ Definer, Guy Who Actually Used a Winch Once
You got a picture? Curious to see what they actually look like, might change some of the suggestions here if folks can see the actual cupping and how it's presenting.
bigfoot21075
bigfoot21075
Robert
Maryland
They are outrageously loud and the cupping is bad enough where you can feel it through the body. I am used to loud after 10 Jeeps and Large trucks, but this beats them all by far. They have to go.
tomk62
Tom
South Carolina
2024 JLU Sahara Anvil, 2019 Cherokee
For my education, "cupping" means the center is worn out before the edges? If yes, wouldn't that happen because of over inflation?
