Tazer Mini Issues for 1st timer
rfg9585
Randy
China Grove, NC
2021 JLU Rubicon, 2020 Sahara JLU
retired
Got some good info from Joe! Turns out it must be related to the fact I used MAC to update the mini. (MAC is CRAP) He had to give me an activation code which I entered into the serial# screen using the left arrow\cruise+-| cruise on buttons. I can see menus now, but some features didn't work as expected. Probably me needing to understand the details behind each a little more. Thanks all for input.
WranglerMan
Will
Greenfield Indiana
2018 Wrangler JLU Sahara
I know lots don’t like MAC but that all I use, not running a Tazer but using JSCAN and never had a single issue, I’m thinking ZAUTO needs to do some tweaking on their MAC software not everyone gobbles up MS.
Shots
Winchell
Ohio
'22 Rubicon
WHAT WILL YOU USE YOUR TAZER FOR? NEVER HEARD OF THESE UNTIL YOUR POST.
I've heard of all of those features. In-motion Nav is a great feature. Now my wife can type in a destination while I'm driving. I understand why FCA blocks it so the driver isn't distracted, but it's one of my favorite Tazer features.
I've also adjusted the TPMS warning threshold, and the ESS automatically stays off when I turn the Jeep on.
I don't use turn cam, but I do use the reverse camera like a second rearview mirror (to keep an eye on the trailer/load) when towing. I like that the camera stays on instead of it turning off after a few seconds.
Rhinebeck01
Ormond Beach, Florida
Retired at 55 ..
@Shots
In regard to In-motion Nav, (Yes, terrific Tazer JL feature offering) DO, be sure when you reach your destination to turn off In-Motion .... Again, be sure you turn that feature off...
IF, you do not turn it off, you risk coming out in the morning lets say, to resume your trip, only to find your battery(s) dead..
In the instructions ZAutomotive (Joe) says this... "It is recommended to leave this setting OFF, enabling it only when you need to use it, as it can cause an occasional radio reboot right after engine start-up."
Indeed, it does as mentioned in the instructions but along with that, you may see UConnect reboot repeatedly all night when the vehicle is parked and thus the battery(s) depletion. This repeated rebooting does not always occur, but can/ has been known to happy.
Early on when the feature was debuted and this quirk was not known by Joe and user's, I fell victim to this.... I was 400 miles away from home and fortunately, I knew how to get myself out of the jam I found myself in. I
Shots
Winchell
Ohio
'22 Rubicon
That's good to know. Thanks for the heads up.
Rodeoflyer
Bert
Conifer, Colorado
Hood alarm is a default setting.. i don't have it listed either but it's active. I know because some thieves have tested it :). Great feature!
jludave
The Isle of Long
IT Manager
The JL doesn’t have a hood alarm by default. The Tazer adds that functionality as a live feature. It has to be enabled.
If you’re not seeing it in the live menus, something isn’t right.
Rhinebeck01
Retired at 55 ..
Yes, should be seen in Live Menu.
Only other mentionable about the hood alarm feature is ......... Turn hood alarm on/off. Mandates/Requires that Set Panic is enabled. Another words you have not disabled the panic button on the fob(s) via the associated Tazer JL feature.
Rodeoflyer
Bert
Conifer, Colorado
I'll have to play around with it today. I purchased it for TPMS modification, rear locker in 2wd, and swaykill, which all work great. I'll check out these other 'live' features.
Anyone know how to lower the TPMS below 25psi or is it suggested to just fully disable it at that point?
jludave
The Isle of Long
IT Manager
25 is the lowest setting the vehicle will allow. It’s not a Tazer limitation.
Most will disable TPMS at that point.
WranglerMan
Will
Greenfield Indiana
Turn it off and buy a tire gage
SouthernJL
Isom
Georgia
2007 Camry and 2014
I have an order of wheels and tires on the way and I completely forgot I'll need a recalibration tool so I guess I'll order the Tazer. Does anyone know if shipping for these is taking a while (lack of supply) or should I expect one pretty quickly? @Rhinebeck01 you seem to know a lot about these things. Would you happen to know?
Rhinebeck01
Retired at 55 ..
@SouthernJL
Order from ZAutomotive's website. It will ship right out.
Do yourself a favor and also order the SGW Extension cable at the same time.
