Tazer JL Mini
Shark
Maui
Tyson’s, Va
2018 JL Wrangler Unlimited Rubicon
I’m having a problem with my Tazer Mini. I was running 11.0.6 and all seemed OK. I took it in to check for updated firmware, found that I had the latest installed, but there was the new beta 11.0.7 to try. I updated and reinstalled it into my JL. Now see nothing on the EVIC when I press the left arrow on the left side of the steering wheel and the left button on the right side. No menu whatsoever. I have tried many different avenues to resolve it, like rebooting the 8.4 inch unconnect, backdating the firmware back to 11.0.6, and nothing. It looks like some of my settings are still active, but I have no way to do anything anymore.
Any ideas on how to fix this? Anyone know how to troubleshoot this? Thanks in advance for any help!
WranglerMan
Will
Greenfield Indiana
2018 Wrangler JLU Sahara
@Shark you may want to try going to either the Windows version or Mac version and then go to the recovery section, I utilize the Mac version and there is a recovery section that basically formats the Tazer
Ormond Beach, Florida
Retired at 55 ..
I disagree..... The guy would be better off, to FIRST, talk to ZAutomotive (Joe) before he does this. After Joe or one of his staff says to do, then do.
I do believe that ZAutomotive will walk the guy through the recovery process. It is prudent to have ZAutomotive be part of the cure so to speak.
IronScott
NW Arkansas
2019 JLU Sahara, 1992 Jeep YJ, 2002 Chevy Silverado
I’ve had a couple oddities happen. At times my ESS state does not reset to its previous state, even making sure to let the EVIC cycle through before driving. I’ve found that putting into gear too quickly upon a start seems to cancel the ESS - for me at least.
Also, a couple days ago the ESS kept cycling on and off during a drive. Didn’t happen before and hasn’t since, though I don’t drive a lot. May or may not be Tazer related or anything to worry about but was odd.
I also reset my tire pressure warning but it took a few tries for me to get it right. When I’d set the pressure amount the TPMS setting would revert to off and I had to set it to on again. Finally seems to be working.
I’m running 11.0.7.
Very happy with the unit. A pain in the arse to install, well, actually getting those stock connectors removed was the pain. Plugging into the Tazer was cake.
Shark
Maui
Tyson’s, Va
Z Auto has been great to work with, and very responsive. All good. Thank.you!
Retired at 55 ..
I’m running 11.0.7.
@IronScott
Good possibility that final release firmware 11.0.8 , will be made available today or in a day or so.
Joe says he has ESS, hiccups and other quirks, taken care of in 11.0.8.
You will want to move to 11.0.8 as I will be doing.
Remember to unmarry first and then do the firmware change. After the firmware change, then remarry and then, check/do settings.
IronScott
NW Arkansas
@IronScott
Thanks for that note. The firmware update works well. Glad to hear he’s putting out more fixes and improvements.
Troutster
Tristan
Keller, Texas
2 Door Sport S
i am having a few issues with my Tazer JL Mini, and to be honest, the “tech support” text line is next to useless. You would think that with a +$300 purchase you’d be able to speak with someone.
With TurnCam enabled I have 2 issues.
1. After completing a phone call on vehicle Bluetooth, the radio always reverts to FM radio as opposed to XM. There is also a 10-15 second pause in between the time the call is finished and the radio resumes.
2. When the turn signal is deactivated during a phone call and the UConnect switches back to radio/phone, the volume reverts back to “7”, making it nearly inaudible.
The issue of the temperature reading 106° when it is 40° outside seems corrected.
How much can I buy your Tazer off you for? :CWL:
But seriously...
How much?
JMurph
Jerry
Bell Canyon CA
2019 Sahara
I have a taser mini in my 2019 JLUS and it works great.
I had a check engine light come on so I unmarried it and I had it in service about a month ago and there was some sort of smog leak. I remarried it and it worked great. Couple days after I got it back I had the same code come up. So I went back in the shop. I unmarried it again. When it came out of the shop they showed me a picture of wires that had become exposed. So they re-wired it with a new (larger) connector, so now I can’t plug my mini in.
Anybody have anything like this? It looks like my fix would have to be a new connector to come from joe@zautomotive. Any suggestions?
Thanks
Jeep Wrangler JL Tazer JL Mini 81040E21-BA69-4F2F-A485-D38BB1DEA442
Jeep Wrangler JL Tazer JL Mini 0C009E17-DC06-4247-B5B7-C0A8FCA51F65
johntrey81
San Antonio
2021 Jeep Willys
I noticed that, with the Tazer Mini, you can change the single climate zone to dual climate zone.
My question is can the Tazer make the Dual climate zone function an in-sync, single zone climate control?
IT SO ANNOYING HAVING TO ADJUST THE TEMP ON BOTH SIDES OF VEHICLE. Maybe some has a hack for that...would be nice when i want to adjust the HVAC, i can do it by pressing one button rather than adjusting 2 climate zones to match.
Buff
Bixby OK
1999 Jeep Wrangler Sahara, 2020 Jeep Gladiator Rub
Buff
Bixby OK
Marry....unmarry? Wtf? My ex didn't unmarry me. She divorced my arse! From now on I will marry and divorce my Tazer!
Good idea!!!!! You could show a little more respect for others on here. Just cuz you got your panties in a twist, others really don't care about your personal problems. Maybe she had a really good reason to leave you. Possibly you shouldn't have bought something that expensive if you don't understand how it works or don't bother researching the product prior to purchase.
Alesimo
Alec
Houston
2020 Jeep Wrangler JLUD
jludave
The Isle of Long
IT Manager
I know this is an old post, but if you have the dual zone climate control, you can go into the control and press the SYNC button. From then on any time you adjust the driver side temp, the passenger side will match. Adjusting the passenger side will override the sync.
