Tazer JL Mini writeup?
Eischman
Kevin
Hortonville, WI
2021 Rubicon Unlimited
Has anyone done, or know of a site that explains the Tazer Mini in detail?
For instance, when would you want to change your Gear Ratio, and when would you want to change your Transfer Case Low ratio?
I understand how to do it, but in what circumstances would you do it?
Apples491
Nick
Denver, CO
2022 JLUR in Hydro Blue, 2024 Nissan Ariya
You would change those things if you regeared those things ....
Most of the settings in the vehicle settings menu are there to turn features on and off. Removed the FAD? There's an option to turn it off so the Jeep isn't expecting to see it. Added the factory front camera? There's an option to turn on that stock functionality.
Eischman
Eischman
Kevin
Hortonville, WI
Thanks
Okay, in other words, if you did not change any gearing to begin with, don't worry about it.
Terpsmandan
Penn Yan
Main things I use mine for is tire size and turning that darned ESS off. Also when the shop got me the wrong tire monitors and I had to wait for new ones, I turned the tire monitor off.
MilkSteak
Palm Springs, CA
2022 JLUR XR
It's also good for adjusting tire pressure settings. You can turn off the warning light too when you air down off road
LuvHydro
Midwest
21 JLUS Hella , 22 JLUSS Hydro
Ask @Rhinebeck01
