bjm00se
- Steve
- Jan 26, 2021
- California
- JLUR 6sp ordered 11/3/21, picked up 8/30/22
I don't claim to be an expert here. Far from it. To the contrary, I think the benefit I bring to any potential discussion here is as an uninitiated user.
Time was I worked on accounting software. I used to joke that our product was "the software folks loved to hate" because it had quirks and oddities that made it much harder to pick up and use than you'd ideally like; and yet, people keep using it because it let them run their businesses like no other product would. But I digress.
Anyhow, Tazer is kinda like that. I love it, because without it - my modified Jeep wouldn't work right at all. But MAN it's quirky, and therefore I also hate it.
Start off with the manual. All 15 pages of it. It's OK. You can see they're trying. But it could still be better.
NOOB LESSON ONE: Allow time to read the manual. It's important.
Yeah, you want to read through that to see what it can do for you. But, some of the descriptions are terse, and what you think they mean, vs what they actually mean, may not always line up. An example is: (text edited from original) the OffRoad menu "SwayBar" setting. You set it to "YES" to indicate that you've REMOVED the original Rubicon electronic swaybar. Then in the "live" section, there's a separate function titled "SwayKill" to allow use of sway bar disconnect in 2wdIn newer versions of the software, on the display it's called "SwayBar Kill" (or was it SwayKill?) and you turn it ON if you've REMOVED the Rubicon electronic sway bar. But the manual still just calls it the "SwayBar" setting.
And another place in the manual. There's some description, some description about the radio display, and then "Turn It Off." Do they mean turn the JEEP off, or the RADIO off? I'm pretty sure they meant the Jeep. But still to this day not 100% sure.
And "anchor mode" for winching. That seems really useful; be able to run your winch on the Jeep while not simultaneously sitting in the driver seat holding the brake pedal. I thought I followed the steps, but what I did didn't cause anything to happen. So I've got "some more learnings" to get before I can activate that feature.
NOOB LESSON TWO - After reading the instructions, you may still need to try things a couple different times or a couple different ways to get the result you expected.
And that leads us to setting the programming. The most important pages in the manual are pages 5 and 6, which tell you how to access the settings programming, and the critical "reboot" steps that are performed after you change settings.
You have to have the dash display (i.e. the digital display between the tach and the speedo - they call it the EVIC display) set to the "audio" page by using the up/down controls on the left side of the front of the steering wheel. Once there, Tazer has you control the programming by using key combinations of the left side arrows and right side cruise-control buttons to program the tazer.
But while you're doing that, the dash display keeps flipping up Jeep messages about the cruise control features that are not active while you're in this mode. This does NOT inspire confidence in the user. Did I do it right? Am I in the wrong mode?? Jeep thinks I'm trying to activate cruise control instead of program Tazer. Arg!
NOOB LESSON THREE - Don't be distracted by "cruise control" messages you see while trying to program Tazer. Ignore those and proceed.
SUGGESTION: We're have the display in audio mode here. On the BACK of the steering wheel are buttons dedicated ONLY to audio controls. Why doesn't Tazer programming take its input from those controls instead? Perhaps there's a good reason, but that would seem to me to be an aid in avoiding needless distraction and confusion.
But that's really only the beginning of my Tale of Quirks and Oddities. My Jeep has a six speed manual transmission. When you change the tire size on a manual, there's an ENTIRE manual supplement on additional steps you have to take to get the Jeep to recognize those settings:
FURTHER EDIT - folks don't seem to be aware that I'm both aware of and specifically referring to this supplement on the Zautomotive page. If you're changing tire size or gear ratio on a 6sp wrangler, you need this supplement!
https://www.zautomotive.com/zpu/instructions/jlm6relearn.pdf
(EDIT as of Nov 2024 - I recently looked at that document. Sometime in the intervening two years, the doc has now been updated to instruct you to perform a battery disconnect. Yay!)
BUT -- EVEN AFTER following those instructions (which I printed out and did)
You may STILL experience the following failure:
I followed those instructions multiple times, as did the shop that installed my gears and tires. Finally, on this forum, I connected with a couple other owners of 6 speed JLs. They both confirmed that for the new size to fully be accepted, an additional step, not listed in the manual, needed to be performed - disconnect the battery for 30 minutes to reset the computer. (I won't describe those steps here. Suffice to say that simply disconnecting the black negative terminal on the main battery is NOT sufficient.)
THAT was the magic incantation to get ESS working again with the new tire size.
OK! Great! We're done! The Jeep is working and I won't need to change anything. Except. After a long road trip, I came to realize that 37psi is really not required, nor particularly comfortable, when running oversize 37" tires. After a quick "chalk test" and some driving, I settled on 28psi. Tazer lets you change the TPMS threshold. Yay! I've got this programming down cold now. How hard could it be? A quick run thru of the steps, change front/rear PSI and.....
Oh My Gawd.
Check Engine Light. ABS light. SRT radio display. Fuel indicator shows weird combination of completely full/completely empty. U0140E. "Implausible Vehicle Configuration Received" U0415. BCM U1514-87
What. In. The. Actual. Fuck?
OK. No problem. Part of the process in solving any hard complicated problem is what I call "problem solving mindset." This has two parts:
Google showed me that other folks have experienced other similar problems after using Tazer.
1. It's not JUST me.
2. It's solvable.
NOOB LESSON FOUR: Don't Panic!
I'd recently had good experience by doing full battery disconnect reset. So I tried that first. No dice. Nothing changed.
Forums suggested that once in this untenable state, the best approach is to "UnMarry" the Tazer to return to stock configuration, and start over. This I did.
Navigate through all the menus and write down on paper all my custom configuration settings. Tire size. Gear ratio. Swaybar Kill. Front TPMS. Rear TPMS.
Use the Tazer to clear all the current trouble codes.
Unmarry. (full reboot and two sleep cycles)
Marry. (full reboot and two sleep cycles)
Navigate through all the menus re-applying my Jeep's custom settings.
Full reboot and two sleep cycles.
Restart. Voila! No errors! It works!!
I still have no idea what caused the weird state errors. Maybe I fat-fingered some setting. Maybe I had my foot on the brake during the reboots. Maybe the steering wheel wasn't perfectly straight. Maybe the Tazer was hit by stray cosmic radiation from a solar flare.
SUMMARY NOOB BEST PRACTICES AND LESSONS:
- Gears one thru four function normally.
- then, 5 to 30 seconds after shifting into 5th or 6th gear, you'll get an ESS error on the dash.
- the gear position indicator will blank out.
- the front and rear camera displays will cease to work
- ...until the next time you restart the Jeep.
Oh My Gawd.
- Being open to any new information about the problem, whether or not it agrees with what I *think* I know about the problem
- Absolute confidence that the problem WILL finally be solved, and the only unanswered question is, how long will it take to come to a resolution?
2. It's solvable.
- Allow more time than you think you'll need, and don't be in a hurry.
- Print out the instructions, make an extra copy of page five "Menu Navigation" to leave up on the dash for quick reference to keystrokes while separately turning to whatever menu page the description of the current setting/feature is on.
- It's probably best to record all your settings on a separate piece of paper.
- Navigating settings will generate irrelevant "cruise control" messages on the dash display that you should ignore.
- You have to "full reboot and two sleep cycles" after changing settings, but you can set ALL the settings you want, and THEN go thru the reboot process. You don't have to set/reboot, set/reboot, set/reboot etc....
- The instructions point out that full reboots should have the wheel straight and your foot off the brake. That's probably important.
- Don't Panic.
- You may need to disconnect the battery to get your settings fully accepted.
- You may need to unmarry the tazer and remarry, especially if you do something wrong along the way.
