footose
- Apr 17, 2020
- Kitchener, Ontario, Canada
- 2019 Jeep Wrangler Sport
Tazer Version 11.2.1 (Release 04.23.20)
I live in Canada, and getting a Tazer JL Mini here ends up costing about $500 Canadian after exchange, shipping and duty, which is pretty hefty. So I expect things to work.
I understand that this is a "hack" - and obviously there are bugs and unexpected things are happening, so take this with a grain of salt - but here is my experience over the last week:
I purchased the Mini to do the following, and here is my review of the things:
#1) Code my OEM LED Headlight upgrade so the highbeams would work with the lowbeams and fog lights.
#2) Code my OEM LED Halos
#3) Change lane camera
#4) Double tap mute button camera
#5) Change wheel size
#6) Lightshow
Still worth it? Well... for the OEM LED Highbeam / lowbeam / fogs and Tire Size change and on occasion light show.. I'm not sending it back. I'm sad I can't use some of the advertised features however.
No issue, OEM LED works now with Highbeams and Lowbeams on.
I needed to add the OEM harness for my JLS, which I did. This coding does not work at all. Now, I'm not sure if this is the fault of the Tazer or actually Mopar (Dealer couldn't get it to work either), however, there is nothing on the Tazer site saying this doesn't work for 2019 models. I specifically bought this product to do this, it's advertised to do it, and it does not work.
This was super exciting to have and another reason I was buying the Tazer - but turned out to be absolutely useless and has two MAJOR problems.
a) If you are listening to spotify, when you change lanes, spotify pauses completely and you have to manually restart it.
b) If you are on the phone on bluetooth, if you change lanes, the phone goes to half volume every time you change lanes. It's very annoying and makes this mod useless.
This is probably the most "buggy" feature, next to the light show. If you double tap, your volume still mutes. Sometimes you will be "stuck" in the camera mode when your volume is muted, so you actually can't get back to the radio screen and "unmute".
The reason this happens (IMO), is because this isn't a "double tap" in a short succession. This is more "press mute twice", regardless of time interval. This causes so many glitches. I just drove around this morning with my backup camera on and on a phone call because I didn't want to mute an important call by accident and get stuck in a loop. Again, useless.
I haven't done this yet, so I can't comment. From other forum posts, it I would assume this would work.
#6) Lightshow
Obviously this is a gimmic, so you can't knock it - and it's actually why I found the Tazer in the first place - but turned out not to be the reason I bought the tazer (good marketing?). Couple things with this - it takes a few seconds to activate / deactivate the lightshow. Which, let's face it, you're going to try to use this thing while driving. I strongly suggest you DO NOT. The fun goes away real quick if you can't turn it off really quick and it takes a second or two (which may as well be forever when you want it off) to turn off. When you actually turn it off, your entire lights go out.
Offroad use only. Otherwise, VERY COOL gimmick, that you'll use 3 times and forget about.
That's it for my review. These are my own personal experiences and after about a week of usage.Still worth it? Well... for the OEM LED Highbeam / lowbeam / fogs and Tire Size change and on occasion light show.. I'm not sending it back. I'm sad I can't use some of the advertised features however.
