Obi Wan
- Obi
- May 14, 2022
- Tatooine, Outer Rim
- Website
- starwars.fandom.com
- 2023 JLU SPORT S 2.0, 2004 TJ SPORT 5.3LS
- Occupation
- Jedi Knight
I spent considerable time reading the manual, and *trying* to do everything correct, AND working with a shop that's done many tazer installs. They were as mystified as me, and unable to resolve the problem with tazer support, as far as the sixth gear ESS issue.
It all listed right in the user guide my manI followed those instructions multiple times, as did the shop that installed my gears and tires. Finally, on this forum, I connected with a couple other owners of 6 speed JLs. They both confirmed that for the new size to fully be accepted, an additional step, not listed in the manual, needed to be performed - disconnect the battery for 30 minutes to reset the computer. (I won't describe those steps here. Suffice to say that simply disconnecting the black negative terminal on the main battery is NOT sufficient.)
I don't believe you or your mechanic are reading the most recent user guide as the problem you ranted about is clearly listed in the troubleshooting section of the most recent one posted on Zautomotive's website (I've attached it for your viewing pleasure)
With that said, it's up to you to make sure you have the correct information.
